Cisco UCS Management Pack for VMware vRealize Operations
33888
UCS Management Pack 2.0(5) for VMWare vRealize Operations Manager 8.0 and 8.1
This version of the management pack supports VMware vRealize Operations Manager 8.0 and 8.1
  • Added support for VMware vRealize Operations Manager version 8.0 and 8.1.
  • Performance improvements.
  • Used token based authentication to invoke vRealize Operation Manager APIs from the plugin.
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(5)
Release Notes:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/b_RN_Cisco_UCS_MP_Release_2x_For_vROps.html
UCS Management Pack 2.0(4) for VMWare vRealize Operations Manager 6.6.1/6.7/7.0/7.5
This version of the management pack supports VMware vRealize Operations Manager 6.6.1/6.7/7.0/7.5 with the following new features:
  • Updated the dependent libraries.
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(4)
Release Notes:
UCS Management Pack 2.0(3) for VMWare vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7/7.0
This version of the management pack supports VMware vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7 and addresses few bugs along with new features as:
  • Support for manual discovery of the resources
  • Support for creating adapter instances using proxy server
  • New Resource kinds, metrics and properties related to S3X60 chassis and severs.
Download link:
https://software.cisco.com/download/release.html?i=!y&mdfid=286305108&softwareid=286305820&release=2.0(3)
Release Notes:
Release Notes for Cisco UCS Management Pack, Release 2.x For VMware vRealize Operations Manager - Cisco
UCS Management Pack 2.0(2) for VMWare vRealize Operations Manager 6.2/6.3/6.4
This version of the management pack supports VMware vRealize Operations Manager 6.2/6.3/6.4 and addresses few bugs.
Download link:
https://software.cisco.com/download/release.html?i=!y&mdfid=286305108&softwareid=286305820&release=2.0(2)
Release Notes:
UCS Management Pack 2.0(1) for VMWare vRealize Operations Manager 6.0/6.1
Happy to announce that UCS Management Pack 2.0 for vRealize Operations 6.0/6.1 is on Cisco.com.
This pack contains UCS Manager Adapter which helps in monitoring the UCS domain physical infrastructure within vRealize Operations. It provides correlation between the UCS physical and the VMWare virtual infrastructure components and features several capabilities including UCS inventory, monitoring UCS health and alerts, viewing correlations and I/O power, temperature performance metrics from within vRealize Operations.
Download Link:
https://software.cisco.com/download/release.html?mdfid=286305108&flowid=79283&softwareid=286305820&release=2.0(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
Release Notes:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/UCSM_vROps_RN_2x.html
User Guide: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/User_guide/b_UCS_mgmt_pack_vROps_UG.html
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities. Send your suggestions for new features to ucs-vmw-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-vcops@cisco.com for support questions and ucs-vmw-plugins@cisco.com for roadmap questions, new feature requests and feedback.
UCSM Management Pack 1.1(1) for VMWare vCenter Operations Manager 5.8.x
New features in this release: All of UCSM Management Pack 1.0.1 features plus the following;
  • Support for several new resource kinds - Fabric Interconnect, Server adaptor, server motherboard, fan, psu etc.
  • Metrics and statistics for ports, port channels, adaptors, DCE interfaces, vHBAs, vNICs and iSCSI vNICs
Supported Cisco UCS Manager versions - 2.0, 2.1 and 2.2
Support VMware vCenter Operations Manager versions - 5.8 (5.8.2 and above)
Software Download:
https://software.cisco.com/download/release.html?mdfid=286282669&flowid=72562&softwareid=286283872&release=1.1.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Release Notes:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/UCSM_mngt_pack_vCOps_release_notes.html
User Guide:
Cisco UCS Manager Adapter User Guide, Release 1.x for VMware vCenter Operations Manager - Cisco
Hi Joffrey,
We will take as a requirement for our next release.
Vikramarjuna
Any plans to ever support vROPS integration with UCS Central and not just the individual domains?
Thanks.
Beginner
Is this going to support vROPs 7.5?
Is this going to support UCS 4.0(4) series code?
When is scheduled update for this to happen to support either/both of the above?
Beginner
I am running version 7.5 of vROps and 3.23(h) of UCS. When testing the connection for the management pack I am getting the following error, "Unable to establish a valid connection to the target system. Test failed! Error(551) - Authentication failed".
I have a local read only account configured within UCS that I can login with.
I am using the local administrator password for the vROps connection.
Here is an example of my credentials.
Any ideas??
Thanks!!
Beginner
I think you just need to change how you call the account. I user a readonly account from our UCS environment. The UCS username is simply: readonly I think this should fix you. I am running this on vROPs 7.5, but it is not offically supported and vROPs 8.0 is to be out in just a month or so, so waiting to see if/when that will be supported.
Beginner
Having the same problems as others in that I get the following error in vROPS when trying to connect.
Have tried using different formats for the UCS username to no avail.
Any help is appreciated
Beginner
Is this package being updated for vROPs 8.0? I have attempted to install it and get the below error:
Beginner
Is there any development for a release that works with vRealize 8.x?
There are no plans to support vRealize Operations 8.x
Beginner
Hi reswaran,
any reason for not supporting vRealize Operations 8.x?
Any alternatives?
Cheers,
Fred
Beginner
Any reason for not supporting vRealize Operations 8.x?
Repeating the question as it has been almost 2 months with no response
Beginner
Only guessing, but since Blue Medora has a UCS plugin for vROPs, I assume Cisco has decided they don't need to put out their own.  Seems a lot of 3rd Party plug-ins are going that direction.
Beginner
Any reason for abandoning vROps and this community?  I have tried the Blue Medora plugin and the Cisco Plugin was better.  Will Cisco be supporting vMwares VMware vRealize® Suite Lifecycle Manager™ or is Cisco just ghosting anything VMware now?
Hi All, 2.0(5) of the plugin which supports vROps 8.0 and 8.1 is now released.
Thanks for your continued support and interest in the plugin.
Vikramarjuna
Beginner
Does anyone know if the "UCS Management Pack 2.0(5) for VMWare vRealize Operations Manager" also supports vROPs 8.2.0?
  Randy
Content for Community-Ad
