Cisco UCS Management Pack for VMware vRealize Operations
37846
UCS Management Pack 2.0(5) for VMWare vRealize Operations Manager 8.0 and 8.1
This version of the management pack supports VMware vRealize Operations Manager 8.0 and 8.1
  • Added support for VMware vRealize Operations Manager version 8.0 and 8.1.
  • Performance improvements.
  • Used token based authentication to invoke vRealize Operation Manager APIs from the plugin.
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(5)
Release Notes:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/b_RN_Cisco_UCS_MP_Release_2x_For_vROps.html
UCS Management Pack 2.0(4) for VMWare vRealize Operations Manager 6.6.1/6.7/7.0/7.5
This version of the management pack supports VMware vRealize Operations Manager 6.6.1/6.7/7.0/7.5 with the following new features:
  • Updated the dependent libraries.
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(4)
Release Notes:
UCS Management Pack 2.0(3) for VMWare vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7/7.0
This version of the management pack supports VMware vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7 and addresses few bugs along with new features as:
  • Support for manual discovery of the resources
  • Support for creating adapter instances using proxy server
  • New Resource kinds, metrics and properties related to S3X60 chassis and severs.
Download link:
https://software.cisco.com/download/release.html?i=!y&mdfid=286305108&softwareid=286305820&release=2.0(3)
Release Notes:
Release Notes for Cisco UCS Management Pack, Release 2.x For VMware vRealize Operations Manager - Cisco
UCS Management Pack 2.0(2) for VMWare vRealize Operations Manager 6.2/6.3/6.4
This version of the management pack supports VMware vRealize Operations Manager 6.2/6.3/6.4 and addresses few bugs.
Download link:
https://software.cisco.com/download/release.html?i=!y&mdfid=286305108&softwareid=286305820&release=2.0(2)
Release Notes:
UCS Management Pack 2.0(1) for VMWare vRealize Operations Manager 6.0/6.1
Happy to announce that UCS Management Pack 2.0 for vRealize Operations 6.0/6.1 is on Cisco.com.
This pack contains UCS Manager Adapter which helps in monitoring the UCS domain physical infrastructure within vRealize Operations. It provides correlation between the UCS physical and the VMWare virtual infrastructure components and features several capabilities including UCS inventory, monitoring UCS health and alerts, viewing correlations and I/O power, temperature performance metrics from within vRealize Operations.
Download Link:
https://software.cisco.com/download/release.html?mdfid=286305108&flowid=79283&softwareid=286305820&release=2.0(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
Release Notes:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/UCSM_vROps_RN_2x.html
User Guide: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/User_guide/b_UCS_mgmt_pack_vROps_UG.html
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities. Send your suggestions for new features to ucs-vmw-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-vcops@cisco.com for support questions and ucs-vmw-plugins@cisco.com for roadmap questions, new feature requests and feedback.
UCSM Management Pack 1.1(1) for VMWare vCenter Operations Manager 5.8.x
New features in this release: All of UCSM Management Pack 1.0.1 features plus the following;
  • Support for several new resource kinds - Fabric Interconnect, Server adaptor, server motherboard, fan, psu etc.
  • Metrics and statistics for ports, port channels, adaptors, DCE interfaces, vHBAs, vNICs and iSCSI vNICs
Supported Cisco UCS Manager versions - 2.0, 2.1 and 2.2
Support VMware vCenter Operations Manager versions - 5.8 (5.8.2 and above)
Software Download:
https://software.cisco.com/download/release.html?mdfid=286282669&flowid=72562&softwareid=286283872&release=1.1.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Release Notes:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/vCOps/release_notes/UCSM_mngt_pack_vCOps_release_notes.html
User Guide:
Cisco UCS Manager Adapter User Guide, Release 1.x for VMware vCenter Operations Manager - Cisco
cdhainfra
Beginner
+1 for a version that works with vrops 6.0!
Matt
nnatesan
Enthusiast
Hello!
We are kickstarting BETA for vROps 6.0 plugin starting from Sep 30. Please reach out to ucs-vmw-plugins@cisco.com and engage your account teams for more info.
Nithya
msato0001
Community Member
yes am on version 6.2.0.3528905.Thank you for the information.
reswaran
The pack that will be posted in a week will be supported only in vROps 6.0 and 6.1. Support for vROps 6.2 will come few weeks later.
beausoleil stephane
Contributor
Hi Guys,
is this licences software/tools or if it is free (well we did spend a few millions on the hardware....)
Tx
james.solomos1
Community Member
The customer I am working with is interested for the release that supports 6.2.
Also is an upgrade from 1.01 supported?
reswaran
The release that will be posted by end of May will support vROps 6.2. Upgrade from 2.0.1 is supported but upgrade from 1.x is not supported.
AristizabalC
Community Member
I am trying to install 2.0(2) on vRops 6.2.0 build 3528905 and I always get the error (adapter failed to install).
On vROps I can see the following issue:
2016-06-09 10:43:05,775 [29031] - INFO - vcopsPakManager.setupResourceBundle:309 - Failed to load the resource bundle, exception: Failed to find a resource file from list: /storage/db/pakRepoLocal/CiscoUCS-202/resources/resources_en_US.properties, /storage/db/pakRepoLocal/CiscoUCS-202/resources/resources_en.properties, /storage/db/pakRepoLocal/CiscoUCS-202/resources/resources.properties
Can you confirm the pack is compatible with the version of vRops I am using?
Thank you,
Juan.
james.solomos1
Community Member
I am having the same issue as Juan, we have support on our UCS kit can we open a TAC?
James
AristizabalC
Community Member
Hi James,
After I did a fill reboot of vRops, including taking the cluster offline and then online again I found that on the admin page (https://vrops_url/admin) there was a pending UCS installation on the software update tab, I completed the installation and it worked this time. Apparently there was some stale information on one of the nodes and that prevented the installation to complete.
Hope it helps,
Juan.
kevin.schott
Beginner
Hi everyone.
I have the UCS Management pack 2.0.2 installed on a vRealize 6.2.1 system.  I'm able to see information in the UCS domains, but I seem to be missing the UCS custom dashboards.  Is that a separate install or should that have been installed along with the management pack? I also tried to install version 2.0.1 where the dashboards were first mentioned and still did not see any.  Am I missing something?  Thanks in advance.
-Kevin
nnatesan
Enthusiast
Hi Kevin,
The UCS Manager dashboards comes by default with the management pack, no other installation is needed to view this. Which version / flavor of vRealize do you have - Standard, Advanced, Enterprise?
You should be able to see it under Home -> Dashboard List drop down. See snapshot below;
Nithya
kevin.schott
Beginner
Hi Nithya,
We have vRealize Enterprise version 6.2.1.3774215.  When logging in, even as local admin, I do not see the drop down.  I have uninstalled/reinstalled the management pack a few times and have confirmed the management pack is working and collecting data. Here are some screenshots:
https://goo.gl/photos/CJd4SqYnDyPxwhgu8
https://goo.gl/photos/5EhtTbugzHhQFk7J9
I have also went through all of the sub menus and no UCS menus/dashboards exist.
nnatesan
Enthusiast
Thats strange! I see that you have other plugins installed as well. Can you please send the install logs and the snapshot to ucs-vmw-plugins@cisco.com we will take a look.
Nithya
kevin.schott
Beginner
This was installed a few months ago so I’m not sure how current the logs are.  I can send them and if needed I can uninstall/reinstall then resend the logs.  Where might I find the management pack install logs? Or should I do a support bundle?
Create
Recognize Your Peers
Content for Community-Ad
