UCS Management Pack 2.0(5) for VMWare vRealize Operations Manager 8.0 and 8.1
This version of the management pack supports VMware vRealize Operations Manager 8.0 and 8.1
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(5)
Release Notes:
UCS Management Pack 2.0(4) for VMWare vRealize Operations Manager 6.6.1/6.7/7.0/7.5
This version of the management pack supports VMware vRealize Operations Manager 6.6.1/6.7/7.0/7.5 with the following new features:
Download link:
https://software.cisco.com/download/home/286305108/type/286305820/release/2.0(4)
Release Notes:
UCS Management Pack 2.0(3) for VMWare vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7/7.0
This version of the management pack supports VMware vRealize Operations Manager 6.3/6.4/6.5/6.6/6.7 and addresses few bugs along with new features as:
Download link:
Release Notes:
UCS Management Pack 2.0(2) for VMWare vRealize Operations Manager 6.2/6.3/6.4
This version of the management pack supports VMware vRealize Operations Manager 6.2/6.3/6.4 and addresses few bugs.
Download link:
Release Notes:
UCS Management Pack 2.0(1) for VMWare vRealize Operations Manager 6.0/6.1
Happy to announce that UCS Management Pack 2.0 for vRealize Operations 6.0/6.1 is on Cisco.com.
This pack contains UCS Manager Adapter which helps in monitoring the UCS domain physical infrastructure within vRealize Operations. It provides correlation between the UCS physical and the VMWare virtual infrastructure components and features several capabilities including UCS inventory, monitoring UCS health and alerts, viewing correlations and I/O power, temperature performance metrics from within vRealize Operations.
Download Link:
Release Notes:
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities. Send your suggestions for new features to ucs-vmw-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-vcops@cisco.com for support questions and ucs-vmw-plugins@cisco.com for roadmap questions, new feature requests and feedback.
UCSM Management Pack 1.1(1) for VMWare vCenter Operations Manager 5.8.x
New features in this release: All of UCSM Management Pack 1.0.1 features plus the following;
Supported Cisco UCS Manager versions - 2.0, 2.1 and 2.2
Support VMware vCenter Operations Manager versions - 5.8 (5.8.2 and above)
Software Download:
Release Notes:
User Guide:
Cisco UCS Manager Adapter User Guide, Release 1.x for VMware vCenter Operations Manager - Cisco
Hi Joffrey,
We will take as a requirement for our next release.
Vikramarjuna
Any plans to ever support vROPS integration with UCS Central and not just the individual domains?
Thanks.
Is this going to support vROPs 7.5?
Is this going to support UCS 4.0(4) series code?
When is scheduled update for this to happen to support either/both of the above?
I am running version 7.5 of vROps and 3.23(h) of UCS. When testing the connection for the management pack I am getting the following error, "Unable to establish a valid connection to the target system. Test failed! Error(551) - Authentication failed".
I have a local read only account configured within UCS that I can login with.
I am using the local administrator password for the vROps connection.
Here is an example of my credentials.
Any ideas??
Thanks!!
Having the same problems as others in that I get the following error in vROPS when trying to connect.
Have tried using different formats for the UCS username to no avail.
Any help is appreciated
Is this package being updated for vROPs 8.0? I have attempted to install it and get the below error:
Is there any development for a release that works with vRealize 8.x?
There are no plans to support vRealize Operations 8.x
Hi reswaran,
any reason for not supporting vRealize Operations 8.x?
Any alternatives?
Cheers,
Fred
Any reason for not supporting vRealize Operations 8.x?
Repeating the question as it has been almost 2 months with no response
Only guessing, but since Blue Medora has a UCS plugin for vROPs, I assume Cisco has decided they don't need to put out their own. Seems a lot of 3rd Party plug-ins are going that direction.
Any reason for abandoning vROps and this community? I have tried the Blue Medora plugin and the Cisco Plugin was better. Will Cisco be supporting vMwares VMware vRealize® Suite Lifecycle Manager™ or is Cisco just ghosting anything VMware now?
Hi All, 2.0(5) of the plugin which supports vROps 8.0 and 8.1 is now released.
Thanks for your continued support and interest in the plugin.
Vikramarjuna
Does anyone know if the "UCS Management Pack 2.0(5) for VMWare vRealize Operations Manager" also supports vROPs 8.2.0?
Randy
