amimanda
Cisco UCS Management Pack Suite for Microsoft System Center, Operations Manager (version 4.1.5) is posted on cisco.com
To download the Cisco UCS Management Pack Suite for Microsoft System Center, Operations Manager (version 4.1.5) click here (requires cisco.com login)
Documentation Links:
New features in version 4.1.5
  • Qualified for System Center Operations Manager 2019 UR2
Migration Scripts:
Migration scripts will help you to migrate the UCS Domains and IMC Groups instance templates from the previous version of Cisco UCSM Management Pack or Cisco IMC Management Pack to the latest Cisco UCS Management Pack Suite, Release 4.x.
Supported Management Pack versions for migration
  • Cisco UCSM Management Pack
    • Version 3.1.2
    • Version 3.1.1
  • Cisco IMC Management Pack
    • Version 1.2.1
    • Version 1.1.1
Migration scrips and User Document are attached below.
For a detailed list of UCS Server Faults, please refer to the attachments at the bottom of the "UCS Monitoring Resource Handbook" post:    https://communities.cisco.com/docs/DOC-37197
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco Data Center Communities. Send your suggestions for new features to ucs-msft-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-scom@cisco.com for support questions and ucs-msft-plugins@cisco.com for roadmap questions, new feature requests, and feedback.
amimanda
Hi Orjan,
We have strategically decided to do away with monitors in the Management Pack, v4.x will continue to have rules for UCS faults.
Although, we would be interested to understand the kind of administrative overhead you are facing.
Please raise a support case to discuss further on this.
Cisco Support - Software Downloads, Product Documentation, Support Tools, and Support Cases - Cisco Systems
Amit Kumar
lchua3
Community Member
when CISCO UCS monitoring will be available for SCOM 1801?
lchua3
Community Member
what does this error mean??
Date: 5/4/2018 1:17:06 PM
Application: Operations Manager
Application Version: 7.3.13142.0
Severity: Error
Message:
Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.UISDKException: The page [Cisco.Ucs.MP.UI.ManagementPort.Template.Page.DetailsPage] in the assembly [Cisco.Ucs.MP.UI, Culture="", PublicKeyToken="6c9e6076cdf2c87a", Version="1.0.0.0"] could not be loaded. Please make sure that the account you are running under has sufficient privileges to load the given assembly, or the Management Pack that defines this page is installed or the assembly containing the page is in the path of the executable or that the page derives from known Operations Manager page type. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Cisco.Ucs.MP.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6c9e6076cdf2c87a' or one of its dependencies. The system cannot find the file specified.
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean forIntrospection)
   at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
   at System.Reflection.Assembly.Load(String assemblyString)
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.UIPageSet.CreatePage(String assemblyName, String typeName)
   --- End of inner exception stack trace ---
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.UIPageSet.GetPages()
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.MomTemplatePagesManager.GetPages()
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.PageManagerBase.AttachToFramework(IPageFramework pageFramework, Boolean readOnly)
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Pages.TemplateListPage.AddPagesForSelectedItem()
File name: 'Cisco.Ucs.MP.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6c9e6076cdf2c87a'
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
amimanda
Hi Liang,
This error means that the Management Pack UI dll is currently not available at the expected location.
Sometime SCOM might take a while to place the dll. Please close the operations console and re-open after some time.
I assume you are trying to open the Console on one of the Management Servers.
-Amit Kumar
lchua3
Community Member
it because the SCOM version is 1801 and it cannot access properly? anyidea when it can support SCOM 1801?. the console is installed on separate box which management pack imported manually.
amimanda
HI Liang,
If Console is installed on a separate box, and that box is not a management server then we do not support "launching the Add Monitoring Wizard". Add Monitoring Wizard can be opened from Operations Console  on Management Servers only for this Management Pack related operations
If you do not have console on your management servers then alternatively you can use the cmdlets to add the instances into SCOM.
Regarding adding support for 1801 I will get back to you.
-Amit Kumar
lchua3
Community Member
where can we get the cmdlets and the how to guide via cmdlets?
lchua3
Community Member
Hi Amit,
we manage to get it working on SCOM 1801 provided it must use SCOM 2016 gateway as the Cisco UCS monitoring service only can install on SCOM 2016 or below.
hi
 Cisco IMC Management Pack, Release 1.2.1 supports only till SCOM 2012 R2.
We have SCOM 1801 , and want to monitor cisco IMC, shall i know when will the supported version of mp will be released ?
Also Cisco UCS monitoring service is not supported on SCOM 1801, when i searched found this
Please let us know when will SCOM 1801 supported UCS installable version released
amimanda
Hi Vishawanathan,
You can expect the new MP version with SCOM 1801/1807 support before end of 3rd Quarter CY18.
Amit Kumar
snambiar
What is the latest version of Cisco UCS Management Pack for SCOM 2012 R2, is it still 4.1.3?
Thanks is advance!
sami.khan
Yes. It is still 4.1.3.
Sami
snambiar
Do we have a new Cisco UCS Management Pack for SCOM 2019?
Sreejeet
snambiar
Do we have Cisco UCS Management Pack Suite for Microsoft System Center Operations Manager 2019 available?
Thanks.
doctorouter
previous versions of the management pack auto resolved\closed SCOM Alerts when the alert was closed in the UCS Manager. When you choose to go for Alert Rules, technicians needs to closed the alert in SCOM also.
