** Deprecated - Cisco UCS Python SDK - Deprecated**
32265
This version of the UCS Manager Python SDK has been deprecated please use the UCS Manager Python SDK  located here, Cisco UCS Python SDK - ucsmsdk
The following Python SDKs are available for download from Cisco:
Cisco UCS Manager Python SDK v0.8.3:
Downloads:
Documentation Links:
Cisco IMC Python SDK v0.7.2:
Downloads:
Cisco IMC Python SDK v0.7.1:
Downloads:
Note: Due to the changes in the naming convention of the APIs in the SDK release 0.7.1, scripts written using SDK release 0.6.x need to be modified to make it work with SDK release 0.7.1. Also this version is not compatible with IMC Plugin 0.9.1 for Nagios.
Cisco IMC Python SDK v0.6.2:
Downloads:
For any queries/feedback on the Python SDK, please add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities.
Internal (Cisco) developers/users can contact the team at ucs-python@cisco.com
Jesper,
Incase of java version > 1.7.45, you have to add below line in jnlp file before launching the UCSM.
<property name="jnlp.ucsm.log.show.encrypted" value="true"/>.
Previously for java version <= 1.7.45 we used to add below line.
<property name="log.show.encrypted" value="true"/>
These entry in jnlp file used to populate the UCSM logfile with desired logs which later we use to generate python scripts using ConvertToPython utility.
Hope this will help.
Enthusiast
Rahul
- Thanks, this sounds the correct solution, which I will test
BR
Jesper
Fra: Rahul Gupta
Sendt: 28. august 2014 08:00
Til: Jesper Munk
Emne: Re: - Cisco UCS Python SDK
Cisco Communities <https://communities.cisco.com/>
new comment by Rahul Gupta<https://communities.cisco.com/people/ragupta4>
View all comments on this document<https://communities.cisco.com/docs/DOC-37174#comment-16400>
Beginner
Can any kind person help with the Cisco UCS Python SDK install
Server is Redhat 5.8
Python 2.4.3
On doing the following I get error's , which I assume are not correct
python setup.py  build
/usr/lib64/python2.4/distutils/dist.py:236: UserWarning: Unknown distribution option: 'zip_safe'
  warnings.warn(msg)
/usr/lib64/python2.4/distutils/dist.py:236: UserWarning: Unknown distribution option: 'include_package_data'
  warnings.warn(msg)
/usr/lib64/python2.4/distutils/dist.py:236: UserWarning: Unknown distribution option: 'namespace_packages'
  warnings.warn(msg)
running build
running build_py
python setup.py install
  warnings.warn(msg)
  warnings.warn(msg)
  warnings.warn(msg)
running install
running build
running build_py
running install_lib
Earlier to python version 2.6 we used to install using distutils and these warnings are specific to distutils.
However these warning wont have any impact on installation of package UcsSdk and using its functionality.
You can also suppress these warnings as below:
python -W ignore::UserWarning:distutils.dist setup.py <any-other-args>
Rahul
Hi Drew,
Can you please tell which operating system or platform you are working on?
Also where in your system UCSM logs are generated.
As per our understanding UCSM logs created at “Darwin” platform are stored at ,
$HOME/Library/Caches/Java/log/.ucsm.
Do let us know if the logs are created at different location in your system?
If yes, where ?
Thanks & Regards
Rahul Gupta
Beginner
You have a bug in the fullstate backup in the UcsHandle module (lines 1118 - 1121)
        if type=="fullstate" and not pathPattern.endswith('.tar.gz'):
            raise UcsValidationException('pathPattern should end with .tar.gz')
        elif not pathPattern.endswith('.xml'):
            raise UcsValidationException('pathPattern should end with .xml')
Basically I think you need to revise the elif line to be
elif not type=="fullstate" and not pathPattern.endswith('.xml'):
Thanks Kyle for pointing it out. We will fix it in the next release.
Thanks for the feedback. We will fix the bug in next release.
Meanwhile the correction to the code will be:
backup_types = ["config-all", "config-logical", "config-system", "full-state"]
if type not in backup_types:
                raise UcsValidationException('Valid type values are %s' %(', '.join(backup_types)))
if type=="full-state" and not pathPattern.endswith('.tar.gz'):
elif type != "full-state" and not pathPattern.endswith('.xml'):
- Rahul
Community Member
Do you plan to release a new version of UcsSdk with support for M-series and UCS mini?
HI Neel,
It’s in the roadmap. Let us know your requirement/business case for M-series and UCS mini support which can help in prioritizing this ask and also see if we can suggest any workaround. You can contact us on ucs-python@cisco.com<mailto:ucs-python@cisco.com>
Ravikumar
Beginner
It would be nice to be able to re-attach to a session by means of the cookie. Script 1 creates the UCSHandle and returns the Cookie. Any following scripts would use that cookie to re-attach to the session and do their work. A final script would close the session. This would prevent a lot of logins a use case I am thinking about.
Beginner
I changed the Login method myself to have this feature. I simply added a cookie parameter to the Login Method. If a cookie is specified the cookie self._cookie will be set and the entire AaaLogin method will be skipped. The only drawback is is is that the lastUpdateTime/domains/priv/refreshPeriod/sessionId and version dont't get a value assigned. I don't believe these vars are used in any other method. Will see when I do any additional testing.
I also found a minor bug when the logout is done there is no check if the cookie is already expired. No use to do it when the FI already expired the cookie.
Need to understand the impact and usability if only using cookie to attach to an existing session via Login API without sending AaaLogin method. You need refreshPeriod for autoRefresh functionality. Currently priv is not checked before sending ConfigConf requests so should be fine for a while.
What if cookie is expired then how do you handle the relogin in the second script?
Regarding Logout API, we have added a check to ignore the exception thrown by UCSM if cookie already expired i.e. does not exist in UCS active sessions. This will be available in upcoming UcsSdk version 0.8.4.
- Rahul
Beginner
I am writing a number of modules for Ansible.
The first Ansible module logs in to the UCS and gathers some basis facts including a cookie and maybe the priv. These facts are stored internally by Ansible so they can be used in further Ansible plays.
Subsequent modules would use the previously generated cookie to do their magic
If each module would create a session this would generate a huge load on the authentication system. It could be that each module is executed multiple times. All the modules will be executed after each other and the cookie will never reach its expiration time before the Ansible playbook finishes.
Of course a final module would terminate the session again.
Community Member
I just got started using Python UCS SDK and I'm getting this annoying exception when I'm trying to login to a UCS :
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "C:\Python27\lib\site-packages\UcsSdk\UcsHandle.py", line 362, in Login
    response = self.AaaLogin(username, password, dumpXml)
  File "C:\Python27\lib\site-packages\UcsSdk\UcsHandle.py", line 2373, in AaaLogin
    response = self.XmlQuery(method, WriteXmlOption.Dirty, dumpXml)
  File "C:\Python27\lib\site-packages\UcsSdk\UcsHandle.py", line 214, in XmlQuery
    f = opener.open(req)
  File "C:\Python27\lib\urllib2.py", line 431, in open
    response = self._open(req, data)
  File "C:\Python27\lib\urllib2.py", line 449, in _open
    '_open', req)
  File "C:\Python27\lib\urllib2.py", line 409, in _call_chain
    result = func(*args)
  File "C:\Python27\lib\urllib2.py", line 1240, in https_open
    context=self._context)
  File "C:\Python27\lib\urllib2.py", line 1197, in do_open
    raise URLError(err)
urllib2.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
I'm using Python 2.7.10, UCS SDK python 0.8.3, and the UCS Emulator 3.0.1.cPE1.
I have been searching  around a way to correct it, but no answer.
Is there a way to bypass the cerficate verification or is it mandatory for the UCS to have one ?
Help !
Kind regards
Content for Community-Ad
July's Community Spotlight Awards
