How to make UCS blade server led health state abnormal
liyujoy
In general, UCS blade server health led state is normal. I am testing the UCS blade server with all possible health led states. But I can't reproduce abnormal health led state. So in which circumstance, the UCS blade server health led status can be abnormal. e.g. minor, critical?
mojafri
The severity of the alarm. This can be one of the following:-
Critical—The blade health LED is blinking amber
Minor—The blade health LED is amber
LED Color Changes
These are examples of LED color changes written into the SEL Repository.
34 05 02 2f 00 00 00 20 00 04 24 56 7f 00 04 10 ------------> 534 | 01/01/1970 00:00:47 | BMC | Platform alert LED_MEZZ_TP_FLT #0x56 | LED is off | Asserted
35 05 02 30 00 00 00 20 00 04 24 56 7f 07 04 10 ------------> 535 | 01/01/1970 00:00:48 | BMC | Platform alert LED_MEZZ_TP_FLT #0x56 | LED color is red | Asserted
36 05 02 30 00 00 00 20 00 04 24 58 7f 00 04 10 ------------> 536 | 01/01/1970 00:00:48 | BMC | Platform alert LED_SYS_ACT #0x58 | LED is off | Asserted
37 05 02 31 00 00 00 20 00 04 24 58 7f 04 04 10 ------------> 537 | 01/01/1970 00:00:49 | BMC | Platform alert LED_SYS_ACT #0x58 | LED color is green | Asserted
38 05 02 31 00 00 00 20 00 04 24 5a 7f 00 04 10 ------------> 538 | 01/01/1970 00:00:49 | BMC | Platform alert LED_SAS1_FAULT #0x5a | LED is off | Asserted
39 05 02 32 00 00 00 20 00 04 24 5a 7f 05 04 10 ------------> 539 | 01/01/1970 00:00:50 | BMC | Platform alert LED_SAS1_FAULT #0x5a | LED color is amber | Asserted
Ref: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/faults/reference/3-1/UCSFaultsErrorsRef_3-1/SEL_BMC.html
If you intentionally want to fail some component, i can only think of removing the one HDD which is already in RAID. Blades changes LED color for so may reasons - dimm failure, hdd failure, cmos battery failure etc... few of them in above examples are controller & mezz card fault.
Please rate if you find it helpful.
MJ
Cisco UCS X-Series Energy Efficiency Offer
