Monitoring Rack-unit HDDs via UCS SDK
lopezjairo
I have been working on UCS obtaining MOs and their property values using the Python UCS SDK for monitoring purposes. I have been able to monitor a lot of the equipment but haven't found a particular MO that deals with storage attached to Blades or Rack units. Is it possible to monitor storage via the Python UCS SDK?
Thank you very much for your time!
ragupta4
You can use “StorageController” MO.
Under this specific Storage related MOs are as below:
storageDrive
storageLocalDisk
storageVirtualDrive
storageEnclosure
storageLocalDiskConfigDef
storageLocalLun
storageMezzFlashLife
storageOperation
storageRaidBattery
Thanks & Regards
Rahul Gupta
ragupta4
storageDrive
storageLocalDisk
storageVirtualDrive
storageEnclosure
storageLocalLun
storageOperation
storageRaidBattery
Thanks & Regards
Rahul Gupta
Hello Rahul,
I had completely overlooked the MOs you mentioned. Thank you very much for pointing them out to me. Using what you wrote I was able to monitor the information I required.
Thank you very much!
Cisco UCS X-Series Energy Efficiency Offer
