PowerShell script to check vNIC number Fabric Failover value
reddyks
PowerShell script to check vNIC Number Fabric Failover value on Rack-Mount and B series servers from UCS manager
we need to check Fabric Failover details on all C series and B series servers
in UCS manager .  below is the screen-shot
Thank you in advance.
Brian Morrissey
Using the UCS powertool, this should show you which specific fabric the vnics are assigned to or "A-B" if fabric failover is configured:
PowerTool C:\> get-ucsvnic | select-object Dn, SwitchId
Dn SwitchId
org-root/lan-conn-pol-test/ether-test A
org-root/ls-intersight1/ether-eth0 A
org-root/ls-intersight1/ether-eth1 B
org-root/ls-MyTemplate/ether-1-fabric-A A-B
org-root/ls-Server2/ether-1-fabric-A A
org-root/ls-Server7/ether-1-fabric-A A-B
org-root/ls-template1/ether-1-fabric-A A-B
Brian Morrissey
Dn SwitchId
Thank you Brian for the response, let me check and get back to you.
Cisco UCS X-Series Energy Efficiency Offer
