In our environment there are 15 chassis with 8 blades on each its hard to find mgmt ips of blades.Can we pull this inventory using powertool?
Solved! Go to Solution.
Hi Vineeth,
1. For IP's coming out from management IP pool -
PS C:\> Get-UcsIpPool -Name ext-mgmt | Get-UcsIpPoolPooled | select Id, AssignedToDn
Id AssignedToDn
10.65.183.11
10.65.183.12
10.65.183.13 sys/chassis-1/blade-2/mgmt/ipv4-pooled-addr
2. For static management IP -
PS C:\> Get-UcsVnicIpV4StaticAddr | select Addr, Dn
Addr Dn
10.65.183.10 sys/chassis-1/blade-1/mgmt/ipv4-static-addr
Thank you,
Nitin
Hi Vineeth,
Id AssignedToDn
10.65.183.11
10.65.183.12
Addr Dn
Thank you,
Nitin
Thanks Nitin
This worked.
