UCS PowerTool and VMWare PowerCLI automated management of Auto-deploy
3033
ericwill
Detailed in the video below is a joint PowerShell integration utilizing both Cisco UCS PowerTool and VMware PowerCLI.  The goal of the integration is to show how easy it is in PowerShell to integrate across different functional areas within a virtualized infrastructure stack.  By taking the power of managing UCS with UCS Powertool and coupling it with the power of managing VMware with PowerCLI an infrastructure administrator can fully automated configuration of a net-new cluster of hypervisors from bare metal in UCS to fully configured clusters in vSphere within minutes with very minimal script writing.
There was very minimal prework performed for both UCS and VMware in the environment being demoed in the video below.  For UCS, the prework that was performed was racking, stacking, and cabling the physical UCS gear and performing an initial configuration of UCS manager.  On the storage side, a 200 GB LUN was created and zoned to a range of 18 WWPN's as well.  For VMware, vSphere and Auto-Deploy software were both installed and configured inside of a Windows 2008 R2 server that had DNS, DHCP, and TFTP installed and configured to best practices from VMware for Auto-Deploy.
From there, PowerShell utilizing the Cisco UCS PowerTool module and VMware PowerCLI snap-ins takes over!!!  Three different scripts were created to perform the following functions:
  1. Initial Configuration - The first scripts configures all of the pools, policies, VLANs, VSANs, Service Profile Templates, etc. needed on the UCS side to create new servers to be used in the cluster to be created in VMware.  On the VMware side, this script will download the latest and greatest ESXi hypervisor, as well as create separate Auto-Deploy Hypervisor and Cluster rules that define the hypervisor version and destination cluster for net new servers with the Service Profile Template name provided in the oem strings like "oemstring=$SPT:CL2012", where CL2012 is the service profile template name.  The script will create new service profile from a template, associate it with a server from a pool, monitor the progress of the association and addition of the host into the cluster, perform initial configuration of the new host in the cluster and create a host profile from the configuration, and create a rule for the cluster to use the new host profile.  Downloadhttps://communities.cisco.com/docs/DOC-36049
  2. Addition of New Hypervisors - The second script is run to add new hypervisors to the cluster created in step one.  This script accomplishs that by creating a new service profile from the template created in script one, associating it, and booting it which will cause the server to boot via AutoDeploy based on the autodeploy and cluster rules created from script one, which are triggered from the service profile template name.  The script will verify the host is added to the cluster and is fully compliant with the host profile created in step one.  Downloadhttps://communities.cisco.com/docs/DOC-36046
  3. Rolling Hypervisor and Server Firmware Upgrade of a Cluster - The third script will download the newest version of a ESXi hypervisor from VMware, create a new Auto-Deploy rule utilizing it for servers that are created from the Service Profile Template created in step one.  Once the rules are updated, the script will loop through each hypervisor one by one in the cluster by first setting the hypervisor in maintenance which will trigger VM evacuation, shutting the hypervisor down, change the host firmware pack on the service profile which upgrades the firmware on the server, powering the server on which will cause the server to boot ESXi via Auto-Deploy and rejoin the cluster.  Download: https://communities.cisco.com/docs/DOC-36050
These scripts are provided freely as examples of how you can use both UCS PowerTool and VMware PowerCLI together to achieve end to end automation.  Please feel free to modify and utilize them as examples of how you might automate UCS and VMware in your own datacenter.
Video Link : 11162
Recommendation: The video is best viewed in full screen mode
2 Comments
Thank you so much for creating this. This is exactly the kind of thing I was looking for since I have to setup couple of chassis with 10 blades. This will save a lot of time. Will need to tweak some things and try it out.
ctorlins
Beginner
Hi there, any chance to post this code up on github/datacenter ? It's run by Cisco. Thanks!! Let the community develop more stuff around this , cause it's awesome.
Content for Community-Ad
