DNA center LAN automation SDA
nathanmonteyne0
Beginner
Beginner
Hi Guys,
So currently a customer is migrating to DNA center with completely new switches.
but for the last 32 switches and with these we had the following process:
select your seed device > select the port of the switch > IP pool, hostname etc.
and then after 1 was done we started the other.
now I noticed I can upload a CSV file and that I need to include the S/N and hostname
should it be then possible if I select all ports to the remaining 37 switches in one LAN automation?
kind regards,
Nathan
balaji.bandi
yes you can upload S/N CSV file for automation and PNP
should it be then possible if I select all ports to the remaining 37 switches in one LAN automation?  - Not sure i understand this ? as long ports available to connect with Peer device or l2 device - then you can build 37 swtiches.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/tech_notes/b_dnac_sda_lan_automation_deployment.html
BB
balaji.bandi
BB
