Issues with Cisco DNA Center SDK -dnac.device_onboarding_pnp
Joshua Head
Beginner
Beginner
Hi All,
I have been working on an automation script, I had no issues just using the API's but the dnacentersdk has proven a bit more challenging. Specifically the dnac.device_onboarding_pnp.claim_a_device_to_a_site api call. I am trying to claim a device to site and also passing template parameters for Day-0 claim but I can't get it to work.
I keep hitting the following:
Response:
Params:
Body:
"deviceId": "648d2e79eb9e0b000bca4751",
"type": "Default",
"imageInfo": {
"imageId": "016c6ba2-4630-45f7-9bad-eb9913bf0636",
"skip": true
"configInfo": [
"configId": "71cc2dea-3283-4d18-b699-87c512b66dd6",
"configParameters": [
"key": "Uplink_Interfaces",
"value": "Te1/1/3"
"key": "Port_Channel_1",
"value": "Te1/1/1,Te1/1/2"
"key": "Port_Channel_1_Number",
"value": "1"
"key": "Port_Channel_2",
"value": "Te2/1/1,Te2/1/2"
"key": "Port_Channel_2_Number",
"value": "2"
"key": "Hostname",
"value": "TEST"
"key": "Management_VLAN",
"value": "110"
"key": "ManagementIP",
"value": "10.1.50.212"
"key": "Subnet_mask",
"value": "255.255.255.192"
"key": "Default_Gateway",
"value": "10.1.50.193"
"rfProfile": "",
"staticIP": "",
"subnetMask": "",
"gateway": "",
"vlanID": "",
"interfaceName": "",
"sensorProfile": ""
2023-06-17 13:54:43,622 - urllib3.connectionpool - DEBUG - https://10.X.X.X:443 "POST /dna/intent/api/v1/onboarding/pnp-device/site-claim HTTP/1.1" 500 None
DEBUG:urllib3.connectionpool:https://10..X.X.X:443 "POST /dna/intent/api/v1/onboarding/pnp-device/site-claim HTTP/1.1" 500 None
Response
Status: 500 - Server Error
Headers:
Content-Type: application/json;charset=utf-8
Transfer-Encoding: chunked
Connection: keep-alive
Date: Sat, 17 Jun 2023 03:54:43 GMT
Server: webserver
x-request-id: efb0d9e76f75d0d5343fe86d4cd714ef
Vary: Origin
Access-Control-Allow-Origin: infra-gsudna000.bslmns.bluescopesteel.net
Via: api-gateway
Cache-Control: no-store
Pragma: no-cache
Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval' blob: data:
X-Content-Type-Options: nosniff
X-XSS-Protection: 1
Strict-Transport-Security: max-age=31536000; includeSubDomains
X-Frame-Options: SAMEORIGIN
Body:
"response": {
"errorCode": "ERROR_CODE_N/A",
"message": "JSON parse error: Cannot deserialize instance of `com.cisco.pnp.api.model.ConfigTask$ConfigInfo` out of START_ARRAY token; nested exception is com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize instance of `com.cisco.pnp.api.model.ConfigTask$ConfigInfo` out of START_ARRAY token\n at [Source: (PushbackInputStream); line: 1, column: 155] (through reference chain: com.cisco.pnp.api.model.DefaultProvisionRequest[\"configInfo\"])",
"detail": "Cannot deserialize instance of `com.cisco.pnp.api.model.ConfigTask$ConfigInfo` out of START_ARRAY token\n at [Source: (PushbackInputStream); line: 1, column: 155] (through reference chain: com.cisco.pnp.api.model.DefaultProvisionRequest[\"configInfo\"])",
"href": "/onboarding/pnp-device/site-claim"
"version": "1.0"
I am really starting to bang my head against a wall with this one....
Joshua Head
Beginner
Beginner
Okay for anyone else who runs into this issue I eventually fixed it by using a custom api call wrapper, you can find it in the link below:
https://dnacentersdk.readthedocs.io/en/latest/api/quickstart.html
Search - Adding API call definitions
Joshua Head
Beginner
Beginner
