02-24-2023 05:18 AM
We tried to provision a switch through LAN Automation and we receiveid this error:
"Perform write-erase and reload on PNP device TSPXXXXXXXXX after resolving device issue. Please delete this device from PNP page to retry PNP onboarding."
Switch 9200-48t
IOS:17.6.2
Cisco DNA Center
Version 2.2.3.5
02-24-2023 05:59 AM - edited 02-24-2023 05:59 AM
message contains "after resolving device issue " -> there was a previous message regarding the original issue ?
- write erase (also delete vlan.dat) and reload and inspect the messages
02-24-2023 06:47 AM
Perform write-erase and reload on PNP device TSPXXXXXX after resolving device issue. Please delete this device from PNP page to retry PNP onboarding.
Feb 24, 2023 12:14 AM |
Received show response from PNP device TSPXXXXXXXXX. | Feb 24, 2023 12:14 AM |
Sent show command to PNP device TSPXXXXXXXXXX to retrieve device license information. | Feb 24, 2023 12:13 AM |
Completed Seed Device Configuration phase. | Feb 24, 2023 12:11 AM |
Starting Seed Device Configuration phase. | Feb 24, 2023 12:11 AM |
Re-used existing IP Address 172.X.X.X for interface Loopback0 on device TSPXXXXXXXX, TSPXXXXXXXXXXX role PrimarySeedDevice. | Feb 24, 2023 12:11 AM |
Reserved Subnet X.X.0.0/24 for interface Vlan1 on device TSPXXXXXXX, TSPXXXXXXX. | Feb 24, 2023 12:11 AM |
Started the Network Orchestration Session with primary device: XXXXXXXXXXXXXX. | Feb 24, 2023 12:11 AM |
Starting LAN Automation by user: admin. | Feb 24, 2023 12:11 AM |
02-24-2023 06:48 AM
This was the previous messages.
02-24-2023 08:11 AM
messages are newest at the top
so the previous message was about sent and received show command/response
-> inspect if you can retrieve details of this output, if necessary collect logging from the serial console of the device
