Netconf Connection failure
JohnJudi
Beginner
Beginner
Hi Friends,
In my inventory list in DNAC, I have three switches with error Netconf connection failure in manageability column. I checked and did all the things that DNAC suggested. But I still have this error. In addition , I have below log in CLI:
66495: 066422: Mar 27 08:20:37.484: Switch 1 R0/0: ncsshd_bp: NETCONF/SSH: fatal: mm_answer_sign: Xkey_sign failed: error in libcrypto
DNA Software version is 2.2.3.4 and switch IOS-XE version is 17.3.3
I searched and found a bug related to this error.
 the screenshots of error.
Do you have any idea to solve this problem?
thank you in advance for reply
Dan Rowe
For the quickest resolution, I recommend opening up a TAC case to have them assist with performing the necessary debugs and troubleshooting to provide a root cause. This is a fairly common error that TAC is used to troubleshooting. This error is typically seen when the key to the trustpoint tied to the http/netconf process is incorrect or missing.
When troubleshooting netconf issues, I like to take a tcpdump on the DNAC CLI along with capturing the following logs from the switch:
debug netconf-yang level debug
debug netconf all
show logging profile netconf internal level debug to-file flash:netconf.txt
I recommend collecting the debugs above & tcpdump from DNAC CLI in order to attach them to the TAC case you open.
Dan Rowe
debug netconf all
cth
Beginner
Beginner
Hallo, i had this issue, too.
my solution was:
Inventory --> Actions --> Telemetry --> Update Telemetry Settings --> Check Box "Force Configuration Push" --> Next
wait five minutes and resync the Switch.
