11-24-2022 08:31 PM
Hello, What is difference between DNAC-witness-2.1.2.4.ova and normal DNAC? What does that mean with witness? Thanks
Solved! Go to Solution.
11-25-2022 12:51 PM
Hi interfacedy,
Just had a look at the downloads page for 2.1.2.4, the .ova (~2.5GB file size) is the witness and you also have the .iso (~22.8GB file size) which is the DNA Center image.
Regards.
11-25-2022 01:07 AM
Hi Interfacedy,
The DNA Center witness is used when deploying DNA Center in Disaster Recovery.
The Witness is installed on a 3rd site, it is used to avoid a split brain scenario. DNA Center uses the witness site to arbitrate between the active and standby sites, allowing only one active site at any given time.
Hope that helps.
Regards.
11-25-2022 08:18 AM - edited 11-25-2022 08:19 AM
Thanks! So witness is not main component. Looks like dnac cannot work without main component(ios). Why we only can see witness in cisco download website and cannot see main ios? Where is it?
11-25-2022 12:51 PM
Hi interfacedy,
Regards.
11-25-2022 06:37 PM
Thanks! Looks like home lab cannot run it due to its ram requirement
