tough one. There are a couple of bugs, such as the one below, or 'ip multicast-routing' being configured on the switch.
Can you post the entire running config ?
Unexpected reload (or boot loop) caused by Smart Agent (SASRcvWQWrk2)
CSCvt41134
Description
Symptom:
The affected device might unexpectedly reload, or remain on boot loop, with the following errors:
- Segmentation fault at SASRcvWQWrk2:
UNIX-EXT-SIGNAL: Segmentation fault(11), Process = SASRcvWQWrk2
Conditions:
Triggered by this line of config: 'clock summer-time recurring'
It is caused when the timezone is written in expanded form rather than the abbreviated form.
Ex: "Pacific Standard time" instead of PST
"Central_DAYLIGHT_Time" instead of CDT
Workaround:
When configuring 'clock summer-time recurring' use 3-character string for
Ex: PST or IST or EST or CET
