Catalyst 9000 configuration for DNA center assurance
Hi all,
I have some questions about how to configure a cat 9K for DNAC assurance.
  1. Once I added the 9K's to DNAC I can see the following in the config:
    crypto pki trustpoint DNAC-CA and crypto pki certificate chain TP-self-signed
    For what is this used?
  2. I applied a telemetry profile to a switch, but without configuring network settings for a site.
    It seems that nothing changes in my switch config.
    What would be the use case for the 'telemetry profile'?
    Is this for configuring the switch, or to allow DNAC to receive syslog/snmp/...?
  3. It does not seem to be possible to add a telemetry profile with netflow for switches.
    Does this mean I can't send netflow to DNAC from the 9K's?
    If it is be possible to send netflow, how would I configure this on the switches manually, as there are many possibilities in flexible netflow?
Hi Diana,
Just to correct you .
During device discovery Dnac configures below :
1) PKI
2)IPDT
3)HTTP server & SSH source
4) SNMP RO & RW community
When Telemetry configured for switch then below gets configured :
1) Syslog
2) SNMP traps
You need to configure the telemetry profile for optimal visibility .By default telemetry is disabled .
Cheers,
Dheeraj
AndiBuchmann157
1) DNA-C acts as a "kind of" CA and once you add your 9.4k to DNA it recives a certificate from DNAC for trustworthy naughty things ;)
Diana Karolina Rojas
Hello!
When you apply the telemetry profile to your switch you should get the next configuration:
device-tracking tracking
device-tracking policy IPDT_MAX_10
limit address-count 10
no protocol udp
tracking enable
And this command will be applied in all your access ports:
device-tracking attach-policy IPDT_MAX_10
This way the DNA will collect all the client telemetry information and can use it for health diagnostic and for troubleshooting purposes.
Please do not forget to rate useful post.
Best Regards,
Hi Diana,
1) PKI
2)IPDT
1) Syslog
2) SNMP traps
Cheers,
Dheeraj
