Cisco DNA Premier Licensing Features
telesymbol
Dear All,
we've below BOM and want to use ISE, Prime Infrastructure and other services included in DNA premier but we want to make sure what additional components must be added to use those features and what exact features or services do we have apart from Layer 3 capabilities and please advise.
C9300-48U-ACatalyst 9300 48-port UPOE, Network Advantagepcs2
C9300-NW-A-48C9300 Network Advantage, 48-port licensepcs2
S9300UK9-1612Cisco Catalyst 9300 XE 16.12 UNIVERSALpcs2
PWR-C1-1100WAC-P1100W AC 80+ platinum Config 1 Power Supplypcs2
PWR-C1-1100WAC-P/21100W AC 80+ platinum Config 1 Secondary Power Supplypcs2
CAB-TA-EUEurope AC Type A Power Cablepcs4
C9300-SSD-NONENo SSD Card Selectedpcs2
STACK-T1-50CM50CM Type 1 Stacking Cablepcs2
CAB-SPWR-30CMCatalyst Stack Power Cable 30 CMpcs2
C9300-DNA-P-48C9300 48-Port DNA-Premier Licensepcs2
C9300-DNA-P-48-3YC9300 DNA Premier, 48-Port, 3 Year Term Licensepcs2
ISE-BASE-TISE BASE Term Licensepcs50
ISE-BASE-TRK-3YISE BASE Tracker Term 3Ypcs50
ISE-PLS-TISE PLS Term Licensepcs50
ISE-PLS-TRK-3YISE PLS Tracker Term 3Ypcs50
SWATCH-TStealthWatch 1 FPS Term Licensepcs200
SWATCH-TRK-3YISE BASE Tracker Term 3Ypcs200
CAT-DNA-P-ADDCatalyst DNA Premier Add-On, Term Licensespcs2
CAT-DNA-P-ADD-3YDNA Premier Catalyst Add-on, 3 Year Term Licensepcs2
PI-LFAS-TPrime Infrastructure Lifecycle & Assurance Term - Smart Licpcs2
PI-LFAS-AP-T-3YPI Dev Lic for Lifecycle & Assurance Term 3Ypcs2
C9300-NM-4GCatalyst 9300 4 x 1GE Network Modulepcs2
NETWORK-PNP-LICNetwork Plug-n-Play Connect for zero-touch device deploymentpcs2
CON-SNT-C93004UASNTC-8X5XNBD Catalyst 9300 48-port UPOE, Network Advapcs2
balaji.bandi
Not sure we have understood your question correctly here - DNA premier - means you have a higher level of License.(which cover most of it)
i suggest contacting Local Cisco SE or partner before place an order, what is your requirement, (the kind of investment you putting above BoM) not cheap, so make sure you buying the right product for the right use.
BB
Dear Balaji,
Thanks for your response,
what we want is to all the licenses included in the BOM majorly ISE and Prime Infrastructure but we want to be sure that what additional licenses and hardware are required to use those licenses like
Do we need to buy DNA center in order to use our licenses ?
can we buy ISE server only and use the ISE licenses included in the BOM ?
what additional hardware and licenses do we require in order to use Prime Infrastructure ?
regards
May be i can not give full view since  what business want to do ? what kind of solution you building here. ?
So we do not want to missguide and make your money get wasted, where some soluition not required.
if you buying new DNAC, then you do not need Prime ( but DNAC not 100% of replacement ?)
DNAC is just orchestration tool for SD-Access deployment.
As per Access or Switches looking at there are not many switches here ?
Still i insists to contact Local partner to guide you better and your investment can be protected.
BB
