Cisco Macsec and licenses
LionKin1984
what is the license requirement for Cisco Macsec?
thanks
2 Accepted Solutions
Well hold up, there are some MACSEC licensing requirements, traditionally pre cat9k both TrustSec and MACSEC were IP base/IP services only feature sets.
LAN Base on older platforms does not have any MACSEC/CTS support
With the Cat9k, Essentials has partial support for MACSEC, but not CTS. If you want AES 256 support with MACSEC, then you require Network Advantage.
11 Replies 11
Mike.Cifelli
In regard to ISE licensing, the base session licenses are what you need to support link encryption (MACsec).  Not sure what version you are running, but please note that as of late 2020 and ISE 3.0 there is a new licensing scheme introduced.  See below for further detail:
Products - ISE 3.0 License Migration Guide - Cisco
HTH!
Hi Mike, thanks for your reply, there is no ISE in the deployment
we are using macsec with mka.
thanks again
thomas
MACsec is really a feature of the switch and endpoint that ISE has the option to require as part of the endpoint authorizations. It is a basic RADIUS feature in the Base (2.x) and Essentials (3.x) licenses.
thanks Thomas
thanks Marvin, that means we don't need to renew our DNA advantage license every three years.
thanks
thanks for your reply Damien, yes we are using cisco CAT9K and looks like we will need to renew the dna advantage license after all then,
Note that MACsec-128 is included with the perpetual Network Essentials license though. That does not require any term license or recurring license cost.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Licensing
Hi Marvin, what about C8500? does it require the special license or Hsec license ?
On the Catalyst 8500 platform, a MACsec license is required according to this document:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/security/ios-xe-17/security-book-xe/m-macsec-in-cisco-sd-wan.html#supported-devices-for-macsec-support-in-cisco-vmanage
I can't find the SKU for ordering it but your reseller should be able to help you with that. If you are the reseller, you might reach out to the Partner Helpdesk for assistance.
