DNA A - E licencing vs LAN BASE IP BASE IP SERVICES
jeio
In all slides from Marketing we see positioning IP BASE and IP SERVICES as contrepart of DNA Advantage - this is true if we want all DNA features. But regarding network features IP Base has the sames majors feature as DNA Essentials - can you confirm this ?? Or there is some feature not available - even if we go through feature navigator it is not clear which feature are included in Essentials regarding LAN BASE / IP BASE - thus where can we have a clear list of what is included in Essentials as network feature and if a customer has today IP base we can offer Essentials and why Cisco position always IP BASE to DNA Advantage
txs
jean
Farhan Mohamed
Cisco DNA Advantage delivers policy-based automation with SD-Access, monitoring, and Cisco DNA Assurance. This solution includes Cisco DNA Advantage and Cisco DNA Essentials, with embedded Cisco Software Support. Customers need to buy ISE Base, ISE Plus, and Stealthwatch to enable all Cisco DNA use cases.
Network Essentials = Lan Base.
Network Advantage = IP Base and IP Services.
These are the inclusions as above, if you want to purchase the same please utilize/purchase the licenses accordingly as per the needs.
7 Replies 7
Jeswin S
Please refer Table 9 :  DNA Essentials and Advantage package features in below datasheet,
All features are listed,
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/data_sheet-c78-738977.html#Licensing
Hope this helps,
Hi Thank you but the question was more difference between IP base and Essential/Advantage as Cisco compare Advantage with IP Base .
Hello Jeio!
Answering to your question I recommend you to see this presentation:
http://www3.cisco.com/c/dam/global/da_dk/assets/training/seminaria-materials/Licenses-Networking-for-everybody-with-DNA.pdf
You can see that effectively Essentials is like Lan Base but adding: Basic monitoring and basic automation. Advantage is Like Ip base/Ip services and Enterprise services + SD-Access, Assurance & Analytics.
Please do not forget to rate useful answers.
Best Regards,
ammahend
Agree with everyone below, this simple Video will help you
https://www.youtube.com/watch?v=d7YdvBn6Xjk
-hope this helps-
Farhan Mohamed
If you dont need any of the DNA features, do you need to purchase a DNA license at all?
Hi mr Mohamed , Can you give a link or document descrip Network Advantage = IP Base and IP Services.
thank you Sir.
