Hi there
For 1st experience, I set to participate in a SD-Access project to implement Cisco DNA Center and Cat9K Switches. I'm also responsible for licensing works! In recent days I've studied bunch of Cisco documents, but I'm in confusion now!
My question: Where to activate and register DNA Subscription Licenses? In DNA Center Appliance License Manager, or inside Cat9K Switches? or maybe both?
The project consist of a DNA Center appliance cluster and tens of Cat9300 and Cat9500 switches. Licenses are DNA Advantage Subscription.
There is also one more concern for me:
Is it possible and supported to use CSSM Satellite along with DNA Center to make indirect access to Cisco Account?
Your helps will be truly appreciated.
-Ali
Solved! Go to Solution.
you can register the subscription licenses either manual or via DNAC - it is your choiice. do it just as you wish and how your time (and mood) allows.
Either you do it manually per device (license smart register <ID TOKEN> on the CLI) or you tell DNAC to register every device in its inventory. the second way requires the dnac to be connected to the corresponding smart / virtual account.
in my lab / customers we are doing the lic. manually via satellite and not direct access. i am currently reimaging my dnac to 1.2.10 - i will have look on any options between dnac / sl satellite after its back up again.
hth,
andreas
hth,
andreas
