DNA Center - Remove extended switch port-channel from Edge Switches
lazarmihail
Hi everyone,
Trying to remove a port channel that is not keeping anymore an extended switch and I want to make it an access port but since DNA Center created a port-channel for that extended switch when I try to remove it it returns following error
Anyone can help me with the steps to make it back as an access port?
Hello Lazar. Generally, best not to remove things manually that DNAC automation has pushed. In my 1.3.1 SDA network this procedure worked fine:
1-In SDA fabric site, click the extended node, remove from fabric (Provision > Fabric > Fabric site > Extended node)
2-Delete extended node from inventory (Provision menu)
3-Delete port-channel from fabric edge switch (Provision > Fabric > Fabric site > FE switch with port-channel you want to delete)
Best regards, Jerome
lazarmihail
I tried the following:
- removing the port-channel using CLI and resync the Edge switch ( The port-channel comes up as unavailable and still not being to delete it)
- taking out the interface from the port-channel ( denied by DNAC)
- resync the edge switch and reprovision ( no changes )
