12-10-2019 10:41 AM
Hi everyone,
Trying to remove a port channel that is not keeping anymore an extended switch and I want to make it an access port but since DNA Center created a port-channel for that extended switch when I try to remove it it returns following error
Anyone can help me with the steps to make it back as an access port?
Solved! Go to Solution.
12-17-2019 09:07 PM
Hello Lazar. Generally, best not to remove things manually that DNAC automation has pushed. In my 1.3.1 SDA network this procedure worked fine:
1-In SDA fabric site, click the extended node, remove from fabric (Provision > Fabric > Fabric site > Extended node)
2-Delete extended node from inventory (Provision menu)
3-Delete port-channel from fabric edge switch (Provision > Fabric > Fabric site > FE switch with port-channel you want to delete)
Best regards, Jerome
12-10-2019 10:52 AM
12-17-2019 09:07 PM
