Choose one of the topics below for Cisco DNA Center Resources to help you on your journey with Cisco DNA Center
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
523
Beginner
DNA Center wireless provisioning
We are using DNA Center to provision the wireless over to several sites starting with plug and play of access points and then pushing the desired config via DNA Center provisioning.
One thing that I have not been able to solve yet, is how to rename the access points from default name. The parameters for the initial PnP config does not contain that variable (to my knowledge) and I have not found a way to do that other than doing it via WLC or via Prime afterwards.
Any hints from anyone how to add this as part of the provisioning steps?
Everyone's tags (3)
2 REPLIES 2
Re: DNA Center wireless provisioning
Currently AP rename option is not available through DNA Center, you can rename the AP in WLC or prime, which will not cause any impact.
Aravind
-Aravind
AP rename option is not available through DNA Center.
Content for Community-Ad
July's Community Spotlight Awards
