DNA Centre installation
benolyndav
Level 4
Level 4
can anyone advise the two /21 subnets reuqired for services subnet and cluster services subnet are these addresses just used locally within DNA itself or do these ranges need to be routable and reachable.???
5 Replies 5
Preston Chilcote
If you are doing a fresh install, I recommend downloading the ISO for a 2.x release.  Then, these /21 subnets will be automatically filled in with some 169.x.x.x addresses and you no longer need to reserve them from your company's IP addressing pool.  This only applies to fresh installs, not upgrades to 2.x from 1.x releases.
Hi Preston
Thanks for this info can you point me to an fresh install doc please,
Much appreciated
