02-01-2021 01:07 PM
Hi All-
Looking at my inventory I have a couple f switches that show the above mentioned error. I know that I can fix this from the switch CLI, but there must be a way to do this from DNAC? If I try "copy run star" from a "Run Commands" window, I get "copy run star
Command is blacklisted, execution not supported". What is the proper way to do this?
02-01-2021 01:22 PM
Command runner is a read-only tool. If it could do read-write commands, it would be a serious security issue.
02-07-2021 01:52 PM
