Fusion and Border design/tuning for handoff
hugo.girard
I am configuring the handoff part of the SD-Access for my customer.
To summarize, we have the following VRF/VN :
- GRT/DEFAULT_VN : Underlay
- Corporate_VN
For GRT/DEFAULT_VN and Corporate_VN, the eBGP will finish on fusion routers (catalyst 9500)
1- According to cisco documents, I have initially configured BGP on fusion routers with "maximum-path 2" parameter. But on Border, DNAC do not configure that for the VRF. Do I have to manually add this parameter for each address-family on borders ?
2- On Borders nodes, interconnection subnets (/30) for each VRF are annonced on BGP with network command. For me, it is useless. According to cisco documents, initial configuration of the border (GRT) do not announced interconnection subnets (/30) in GRT.
3- For redundancy, is therebest practices about BGP timers ?
Many thanks for your help.
Hugo
2 Accepted Solutions
ChuckMcF
I'll answer your questions inline below:
ChuckMcF: We manually configured ours (maximum-paths eibgp 2 since our EBNs are connected via iBGP and FRs are eBGP). For clarity, we have dual FR and dual EBNs in our SDA network.
ChuckMcF:we do not have interconnects advertised via network statements. I agree, no point. The only network statements are for those networks in the specific VRFs.
ChuckMcF: my suggestion would be to leave timers alone and use BFD.
VLAN xxxx
bfd interval 100 min_rx 100 multiplier 3
router bgp xxxxx
neighbor a.b.c.d fall-over bfd
HTH,
Chuck McFadden
Xividar
It depends, you only need this command if you have more than one link. If your Border and Fusion have single connections, you don't need to worry about it.
EBGP next hop is changed, iBGP isn't. So that's one thing to consider. If you're using EBGP, the /30's are really only handy for testing. I.E, if you want to ping from one /30 to another /30, you'd need those routes end to end. Going back in to your Shared Ssrvices though, you really need the /32's from each router within your Fabric Domain.
If you own the access network, you can set these really low, plus add BFD.
ChuckMcF
VLAN xxxx
router bgp xxxxx
HTH,
Chuck McFadden
Many thanks for these clarifications.
Xividar
Thank for your help
Hugo
