Help regarding building the SD-Access fabric up
Hello members,
Could anyone can help me who have knowledge on SD-ACCESS implementation.
Could you please help me by sharing the steps to make the fabric up with networking devices. Edge fabric node to Border node.
Then how to add the devices into DNA Center?
willwetherman
Hi @SaubhagyaMishra7219
There is a wealth of documentation online, but I found the following resources very useful when designing and deploying my first SD-Access fabric
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Campus/sda-fabric-deploy-2019oct.pdf
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/SD-Access-Distributed-Campus-Deployment-Guide-2019JUL.html
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/software-defined-access/guide-c07-741859.html
These documents are based on DNA Center version 1.2.X so a bit outdated now, but the principles of deploying and discovering the fabric border nodes, fabric edge nodes (manually or using LAN automation), fabric provisioning, fabric border to fusion handoff etc are the same.
The Cisco Live On-Demand Library also has some great resources on SDA-Access/DNAC that will supplement the above.
Hope that this helps
Will
willwetherman
Will
