Choose one of the topics below for Cisco DNA Center Resources to help you on your journey with Cisco DNA Center
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
625
Beginner
Integration between DNA and Aruba wireless?
I checked compatibility sheet for DNA center but only Cisco devices listed...So for a Zero Trust Networking using DNA with ISE (OR SD-Access), is there any integration for Aruba wireless?
I know the radius authentication would still work for Aruba Wireless when working with DNA and ISE. But any further than that?
4 REPLIES 4
Re: Integration between DNA and Aruba wireless?
Cisco DNA Center does not have direct integration with Aruba Clearpass or any other zero trust network component. However, if you're looking to manage Aruba WLCs along with Cisco gear, you can leverage the multi-vendor SDK capabilities of Cisco DNA Center Platform. Read more about multi-vendor SDK here
Highlighted
Beginner
thanks for the info. I am mainly trying to understand the Aruba wireless capabilities from the Cisco SD-Access perspective. For example, I can have the same micro-segmentation user experience wired or wireless if I built SDA with C9K switches and Cisco WLC/AP. So what are the limitations if i replaced Cisco WLC/AP with Aruba wireless for the same network?
Hi ,
As far as I know   Aruba Wireless controller / APs integration are not supported by DNAC .
Cheers ,
DNA Center will be focused on integration with ISE, but framework is intended to be open to allow other vendors to integrate via pxGrid or API. Integration via RADIUS Proxy through ISE should also be possible.  You can work with the team to meet on your requirements and it would give us a better understanding of each perspective of your design
Content for Community-Ad
July's Community Spotlight Awards
