IP Transit handoff configuration problem
rasmus.elmholt
Level 7
Level 7
I have a pretty simple setup with a single 9300 Switch as C|B|E and configured 2 VNs on the device.
I am not trying to make a handoff towards a router but I cannot get the DNAC to bush the Border configuration to the device.
Every time I try it only gives me an error with:
Provisioning failed due to invalid parameter. The interface gigabitethernet1/0/24 on Device a6aa*******16 has an IP, remove the IP and then use the interface.
On interface Gi1/0/24 i have the following configuration and I have resynced the device:
interface GigabitEthernet1/0/24
 device-tracking attach-policy IPDT_MAX_10
end
Any advise would be appreciated.
rasmus.elmholt
Level 7
Level 7
5 minuttes later everything worked.
rasmus.elmholt
Level 7
Level 7
Hi, nice it worked.
Just wanted to share a tip:
Have a look at Kibana (System Settings > Sytem 360 > Log Explorer) and search for: log:error AND <device ip address>
It will show you a more detailed error message - helped me a lot in such szenarios. (:
.:|:..:|:.Please rate helpful posts.:|:..:|:.
Looks like logs are not configured per default?
Looks like you don't have any logging indices.
Let's add some!
Or am I in the wrong place?
