IPAM configuration issue
yawming
Anyone has some input for this issue ?
Thanks !
  1. Login DNA Center and navigate Setting tab -> IP Address Manager item
  2. Input server name, server url (http://<IPAM server>), username, password, select provider is GENERIC and click view combobox. Problem: the DNA Center send quest /ipam/token to IPAM server. The request isn't authenticated successfully. When I check the log, I see that the password was encoded, so the request is authenticated fail.
Expect: the password needs to be in cleartext otherwise the encoded string will be considered as password and that is the wrong password
vijha
Could you please provide the software version of Cisco DNA Center and IPAM address manager software?
Vibha Jha
Cisco Sales Acceleration Center
sac-support@cisco.com
