10-19-2020 08:56 AM
I am trying to LAN automate some Fabric Edge switches in my setup. But every time I start the LAN Automation it keeps staying in the Initialized state.
The VLAN1 is pushed to the Primary device.
PNP Agents get an IP, and option 43.
PNP Agents contact the PNP Server on http and changes to https. But it seems like there are no jobs for the PNP Agent.
And then it stops at:
*Oct 19 14:40:51.718: %AN-6-AN_ABORTED_BY_CONSOLE_INPUT: Autonomic disabled due to User intervention on console. configure 'autonomic' to enable it. *Oct 19 14:40:52.821: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0 *Oct 19 14:40:53.834: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0 *Oct 19 14:40:54.854: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0 *Oct 19 14:40:58.465: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0 *Oct 19 14:40:59.466: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (pnp-tech-discovery-summary) saved successfully. *Oct 19 14:40:59.467: %PNP-6-PNP_DISCOVERY_DONE: PnP Discovery done successfully (PnP-DHCP-IPv4) *Oct 19 14:40:59.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 14:40:59 UTC Mon Oct 19 2020 to 14:40:59 UTC Mon Oct 19 2020, configured from console by vty0. Oct 19 14:40:59.000: %PKI-6-AUTHORITATIVE_CLOCK: The system clock has been set. Oct 19 14:40:59.003: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0 Oct 19 14:40:59.004: %SMART_LIC-5-SYSTEM_CLOCK_CHANGED: Smart Agent for Licensing System clock has been changed Oct 19 14:41:01.387: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified. Issue "write memory" to save new IOS PKI configuration Oct 19 14:41:02.457: %SYS-5-CONFIG_P: Configured programmatically by process PnP reconnect profile from console as vty0 Oct 19 14:41:02.536: %SYS-5-CONFIG_P: Configured programmatically by process XEP_pnp-zero-touch from console as vty0 %Error opening tftp://255.255.255.255/network-confg (Timed out) Oct 19 14:41:24.086: AUTOINSTALL: Tftp script execution not successful for Vl1. Oct 19 14:41:30.673: %PNP-6-PNP_BACKOFF_EXCEEDS_WARNING_LIMIT: Requested PnP Backoff time (169200) exceeds warning limit (86400) in seconds
Any help on troubleshooting is appreciated. I have done some PCAPs of the traffic but nothing I can figure out.
10-19-2020 09:47 AM
I have seen similar issues in the past which was due to option43 being misconfigured. I would start with ensuring it is configured properly and re-test. Also, verify that proper path/ports are available/allowed. Here are the specifications for option43:
5A1N - specifies plug and play
B2 - ipv4 type
I10.X.X.X - connect to dnac ip
J443 - port # to use
For additional assistance see here: https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/dna-center/215336-lan-automation-step-by-step-deployment.html
This is also a good blog series: https://blogs.cisco.com/developer/cisco-dna-center-plug-and-play-pnp-part-1
HTH!
10-21-2020 10:14 AM
This is configured correctly. And a monitor capture shows the PNPAgents connecting to the DNAC on port 80.
10-19-2020 10:20 AM
Make sure correct license is installed (Network Advantage) and “ip routing” is enabled on Seed device!
Check out page no 33 on below link
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2019/pdf/BRKSDN-2500.pdf
10-21-2020 10:13 AM
My NA license has expired on the Seed device.
but IP Routing is enabled.
