No results in DNA WSA Sensor based test
sergey.dibrov
Hello
We are deploying DNA Wirelesss Assurance with 1800s sensors.
Sensors has been provisioned in DNA-C.
And simpe Test Suite has been scheduled.
But there is no results.
In sensor CLI:
AP70F3.5A7A.0198#show dot11 sensor stats
## Network Assurance Sensor Statistics ##
WSA Status: Enabled
NA Connectivity: Connected
NA Connectivity I/F: Wired  http
NA Server URL: https://10.64.128.127
Auth Type: EAP
HTTP Proxy IP: PROXY_IP
Backhaul SSID: CiscoSensorProvisioning
Id-token:
Port: PORT
Total Test Cases Run: 0
Successful Test Cases: 0
Failed Test Cases: 0
Network Assurance 5G Radio Statistics
Host Rx K Bytes: 0
Host Tx K Bytes: 0
Unicasts Rx: 0
Unicasts Tx: 0
Broadcasts Rx: 0
Broadcasts Tx: 0
Beacons Rx: 0
Beacons Tx: 0
Multicasts Rx: 0
Multicasts Tx: 0
CRC errors: 0
Network Assurance 2G Radio Statistics
Host Rx K Bytes: 0
Host Tx K Bytes: 0
Unicasts Rx: 0
Unicasts Tx: 0
Broadcasts Rx: 0
Broadcasts Tx: 0
Beacons Rx: 0
Beacons Tx: 0
Multicasts Rx: 0
Multicasts Tx: 0
CRC errors: 0
AP70F3.5A7A.0198#
AP70F3.5A7A.0198#show dot11 sensor test config
Test Config Received Time: 2020-01-17 10:47:30.604699
    advancedConfig: {
        rssiThreshold: -75
    testConfig:
            targetAPs:
            testSuiteName: test-1
            bands: BOTH
            scheduleInDays: 0
            connection: WIRELESS
            frequency: {
                value: 30
                unit: MINUTES
            ssids:
                    username: null
                    validTo: 0
                    layer3webAuthsecurity: null
                    numAps: 0
                    authTypeRcvd: null
                    authType: WPA2_PSK
                    ssid: retail-service
                    authProtocol: null
                    eapMethod: null
                    certxferprotocol: HTTP
                    qosPolicy: null
                    layer3webAuthpassword: ****
                    psk: ****
                    layer3webAuthuserName: null
                    bands: BOTH
                    layer3webAuthEmailAddress: null
                    certfilename: null
                    profileName: retail-service
                    password: ****
                    certstatus: ACTIVE
                    wlc: 10.64.0.116
                    certpassphrase: null
                    numSensors: 0
                    status: ENABLED
                    certdownloadurl: null
                    wlanId: 0
                    validFrom: 0
            startTime: 1579257944554
            repeatCountOnFailure: 2
            numberOfApsToTest: 3
            wlans:
                retail-service
            testSuiteDetails: {
                BUILDING: Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439/6266
                AREAID: 32328f6c-3c7a-409a-8e74-6f6130743b8c
                TESTSUITENAME: test-1
                FLOOR: Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439/6266/1
                AREA: Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439
                FLOORID: ba56b83d-a535-4d33-bcc4-2cc45b04851f
                TESTSUITEID: 5e219058a61fa7002016a29f
                BUILDINGID: 307a9eff-c1c4-4074-b9bc-fc7db74c3ddf
            config:
            type: DEDICATED
            testSuiteId: 5e219058a61fa7002016a29f:!_ba56b83d-a535-4d33-bcc4-2cc45b04851f:!_Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439/6266/1:!_307a9eff-c1c4-4074-b9bc-fc7db74c3ddf:!_Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439/6266:!_32328f6c-3c7a-409a-8e74-6f6130743b8c:!_Global/\u041c\u043e\u0441\u043a\u043e\u0432\u0441\u043a\u0438\u0439:!_test-1
    wlans:
            username: null
            validTo: 0
            numAps: 0
            authTypeRcvd: null
            authType: WPA2_PSK
            authProtocol: null
            eapMethod: null
            qosPolicy: null
            psk: ****
            bands: BOTH
            certfilename: null
            password: ****
            certstatus: ACTIVE
            wlc: 10.64.0.116
            numSensors: 0
            status: ENABLED
            wlanId: 0
            validFrom: 0
AP70F3.5A7A.0198#show dot11 sensor test results
AP70F3.5A7A.0198#
NTP has been configured via CLI
AP70F3.5A7A.0198#show ntp
NTP server       Stratum  Version  Last Received    Delay     Offset    Jitter
time.moscow.spo  2        4        1827sec ago      0.000ms   0.000ms   0.000ms
As you see test suite is configured on sensor but there is  no result
Please help to troubleshoot this issue?
Thanks.
You are running old sensor code which isn't recommended since DNAC version 1.2.10. Please attempt to upgrade at least 8.8.263.0:
-- https://software.cisco.com/download/home/286318948/type/286288051/release/8.8.263.0
Since your 1800s sensor has already been claimed and in your DNA center inventory, you can use SWIM to upgrade the software on the sensor from the DNA center GUI.
Dan Rowe
What DNAC version do you have deployed?
What version is the 1800s running?
Hello
1800s Running Image : 8.8.259.0
DNAC maglev, version 1.3.0.3938
sensor-assurance Assurance - Sensor 1.4.0.484
As i see test suits does not run on  to the sensors
