[Q] DNAC Command Runner - Max number of devices and rolling results into a single file
pethomas
Hi Guys
Two questions on DNAC -
1: In early days the number of devices was limited to 5 - is it possible to run the command across hundreds of switches? Is there a scale limitation in the GUI versus API
and
2: In the GUI is appears you have to click on an individual device to see the results of the command - it is possible, when using the GUI, to put the output from all devices into a single file?
Obviously I can work around issue 2 with an API, but sometimes for an adhoc task the GUI is a nice to use.
T
ammahend
checked on 1.3.0.122
I could run on 20 devices.
-hope this helps-
