CCNA study question. is enabling the device to allow user- or group-based access Authentication or Authorization?thanks
The content you are looking for has been archived. View related content below.
Hello,Is it possible to enable DNA AI for wired networks?Thanks.
Hello I have the below issue when trying to backup on DNAC, please assist BACKUP.PREPARE_BACKUP FAILURE DataValidationError BACKUP.maglev-system:credentialmanager FAILURE BACKUP.fusion:postgres FAILURE BACKUP.maglev-system:glusterfs-server FAILURE B...
HiCan I jusy clarify some backup information please? The automation only backup is what you would restore if your cluster went awol and you are recovering all your fabric info? Device configs, hand offs, port allocations, L2/L3 VN info, SGT matrix ...
For some reason one of our pair of WLC 9800 will not accept DNAC-CA certificate.A sync or push of telemetry from DNA fails. All our other devices are fine.If we try a CLI import of the certificate we get this:Trustpoint 'DNAC-CA' is a subordinate CA....
Hi,we have this fresh install of DNA Center 2.3.5.5-70026. I've been able to create areas using the Intent API but I can't create a building.sitePath = "/dna/intent/api/v1/site" headers = {'content-type': 'application/json'} headers["X-Auth-Token"] =...
This CVE has just appeared on the radar and we've got some customers with DNAC/Catalyst Centre asking questions about it. I've had a search on CCO and on here but I can't find any references to CVE-2024-29990. It maybe this is just specific to Azure ...
Hi all, Application visibility service, does not show any info on Cbar and NBar. when I provision, I get message that Application recognition service not installed go to software management. my issue is I don't have access to internet from the DNAC. ...
Hi,I'm trying to integrate the Meraki Dashboard in DNA Center (2.3.5), but I'm running into some issues.In the "Add Device" screen it asks for "API / Password" in the "HTTP(S)" section.If I input the API here, I can get the Organization details, but ...
Hi all,i get a cisco switch, model WS-C3850-24P, and when i'm looking for a OS/firmware update i have to chose between:Catalyst 3850-24P-E SwitchCatalyst 3850-24P-L SwitchCatalyst 3850-24P-S Switch but with show version i get just only "WS-C3850-24P"...
Hello everyone. I'm very new to DNAC or Catalyst Center. I've setup a project with a template to add a simple configuration to switches. It currently has been in progress for 10 days and hasn't made a change to a switch yet. I'd like to cancel th...
Hello all, We have ISE with DNA Center merged. We have a requirement to limit/control the number of users that are allowed to login to DNAC at anyone time. Most Cisco devices can control this but is there a way to do this via ISE RADIUS/TACACS+? I ca...
Hello Comunity, What are SVS-PDNA-T0-E3Y and SVS-PSTL1-T0-E3Y, and what is the difference between them for Cisco C8300-1N1S-4T2X hardware. Kind Regards!.
Hi all, Could you please kindly help me to understand below licenses?Q1. What is the key difference between SVS-PDNA-T0-E3Y and SVS-PSTL1-T0-E3Y?Q2. Is there a big price difference between SVS-PDNA-T0-E3Y and SVS-PSTL1-T0-E3Y?
Hi Everyone,Just want to know if someone answer my query regarding a failover scenario. Catalyst center has three sites i.e. Main site, Recovery site and Witness site.When the Main site is down, Witness detects that the Main site is down and shifts t...
Subject | Author | Posted |
04-25-2024 07:56 AM | ||
04-24-2024 09:16 AM | ||
04-24-2024 04:32 AM | ||
04-22-2024 03:36 PM | ||
04-19-2024 12:21 AM |
User | Count |
1 | |
1 | |
1 | |
1 | |
1 |
