04-19-2022 01:58 PM
I have a wireless sensor near our VIP offices. I recently installed it. It seemed to be working fine but now I am getting a message sometimes on 5ghz a test result says that "Deauthenticated due to Internal reason". There are three access points in the area. This test will work on 2.4 and only works on 1 out of 3 on the 5ghz.
Does anyone know where I can get more info on this message? Is the internal reason on the controller or the client?
Thanks!
04-20-2022 04:36 AM
I´d say it is Sensor internal reason.
Here on this link there´s a list of "eauthenticated due to" but not mention "internal".
One suggestion would be reprovision the Sensor again from scratch and the other is rise a TAC.
04-20-2022 06:35 PM
Make sure your sensor is running the latest software version. Also check to see what ISE radius logs are displaying.
04-21-2022 12:13 PM
Thanks, I checked and they were not on the latest version. I updated them and the problem seems to have stopped.
04-21-2022 11:53 AM
You can navigate to the sensor 360 assurance page for one of the sensors. On this page, you'll see an option for 'sensor logs'. You can download the sensor logs directly from the sensor to the DNAC and review the sensor logs that are included in the bundle. You may be able to figure out exactly why the sensor is not able to authenticate by looking into the sensor logs.
04-21-2022 12:14 PM
Thanks, I am checking that out now. I did a software update and the problem seems to have stopped.
