WLC Sub Package for Catalyst 9300
alex.dersch
Level 4
Level 4
I am trying to find the download link for the Wireless Sub Package for a Catalyst 9300. Can anyone share the link with me?
thanks
Alex
Nathan_Lee
You can find links to the WLC sub-package, along with other SDA related images of the supported platforms, at the SDA compatibility page.
https://www.cisco.com/c/en/us/solutions/enterprise-networks/software-defined-access/compatibility-matrix.html
6 Replies 6
Nathan_Lee
Cheers, Nathan
Hi Nathan,
quick follow up question. I've downloaded the software und uploaded it to DNA Center. Can I push the package from there to the switch or do I have to manually upload the file to the switch?
thanks
Alex
Hi Alex,
Yes, DNA Centre will start a workflow to install the embedded WLC package to the C9K switch when you enable the embedded WLC in fabric site provisioning screen.
Jerome
Another follow up here, if upgrading the 9300 to a newer IOS release what is the procedure to get the sub-package updated?
1-Download de main image and sub-package from Cisco website
2-Import the main image to DNAC
3-Import the sub-package to DNAC
3-Upgrade de switch using DNAC. Both images will be upgraded.
