03-17-2022 02:54 PM
Hi all, i tried two time to deploy intersight appliance for vsphere.
All the prerequisites are ok, the 2 times, installation is blocked on "Provisioning service security data ".
On the first tried, I let the installation at this state during 3 days..a bit long but just want to know if I have to wait.
I re download the OVA to be sure.
In CLI the option 4 give me this details :
Choice #1->4
System Services:
Running 17 Pending 1 Error 0 Total 18
Intersight Appliance Maintenance Shell [Thu Mar 17 21:24:47 2022]
No change in deployment size during install. Current running deployment size is Small.
Installation in progress: Yes, Installer log: 234225905 bytes
Diagnostics Configuration
[1] Ping a host [a] Show current network configuration
[2] Traceroute a host [b] Configure network settings
[3] Run connectivity test [c] Restart services installation
[d] Run Debug shell (Cisco TAC only)
[e] Configure Logon Banner
[f] Generate and Upload Tech Support
Maintenance
[4] Show system services status
[5] Restart system services
[6] Reboot virtual appliance node
[.] Exit
The size log does not grow up, is it a sign?
THanks.
05-27-2022 02:41 AM
Hello Jerome,
Thank you for your question, I see that our TAC Team assisted you with this issue.
From TAC analysis: this issue is due to that the echo pod is failing to initialise and throws an error that port 443 is already in use.
For this type of questions we highly recommend to contact our TAC Team for the prompt assistance.
Best Regards,
Bota
05-31-2022 10:49 PM - edited 06-01-2022 09:42 PM
Thanks for the step by step tutorial. Works like a charm! The solution worked for me thanks to the community and the members for the solution. Point Of Care CNA
