Is it possible to disable RMA in Intersight SaaS consumption model
megha.gupta
Is it possible to disable RMA in Intersight SaaS consumption model?
If yes what are the possible ways?
jvanewyk
Yes, Proactive RMA can be disabled in Cisco Intersight. Please see Opting Out of Proactive RMAs at https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/intersight/215172-proactive-rma-for-intersight-connected-d.html#anc12.
I hope that this helps.
Jacob Van Ewyk
Thanks Jacob
This option using Tags  is   applicable at  account level  only. Is that right statement.
Can we disable RMA in SaaS  using API gateway ? If yes  Please provide the instructions to do so.
Megha
