Docker login for devhub-docker.cisco.com doesn't work
nshimaza
docker login -u iox_docker.gen for devhub-docker.cisco.com results
Error response from daemon: Get https://devhub-docker.cisco.com/v2/: unauthorized: BAD_CREDENTIAL
The password on DevNet document doesn't work.  Also password on this post doesn't work too.
What is the current password?
Don't you have any plant to remove requiring login and make it world readable?
Steve Zhang
Please try to refer to the guide of https://developer.cisco.com/docs/iox/#!docker-images-and-packages-repository. And please note the API key listed there is not new, it is renewed to some value else. You may sign-in the web to check the value.
Where can I get the latest effective key?  I logged in developer.cisco.com but I don't find such thing.  I still see AKCp5aUjQYJTguSVr48NZqcLd9ikd7jGo8qhpYqhZURY4vmiRezszxtZdSzuQ1UgJ1ZDn3u9t and it doesn't work.
