1161
sjur
Beginner
Guest OS not starting on 156-3.M2
We had the guest OS running fine on the 156-3.M and M1b version, but upgrading to the lastest seems it does not want to start.
Doing a bundle install on this fine
ir800-universalk9-bundle.SPA.156-3.M2.bin
We tested to download the image directly and uninstall the bundled version. same result.
Also tried to just install the Guest OS from M1b and M version, but same problems.
IR800#bundle install flash:ir800-universalk9-mz.SPA.156-3.M2 exclude HV-IOS
Installing bundle image: /ir800-universalk9-mz.SPA.156-3.M2, exclude Hypervisor and IOS image..........
IR800#
IR800#guest-os 1 start
Starting Guest OS ...... Done!
IR800#show iox host list detail
IOX Server is running. Process ID: 325
Count of hosts registered: 0
    IOX Server Address: 0.0.0.0; Port: 22222
IR800#
What can we debug here?
IR800#debug iox
IOX debugging is on
IR800#show debugging
IPv6 iOAM debugging error[0]
2 REPLIES 2
chuli2
Hi Sjur,
Please first check if you have the network configured properly.
If the Guest OS has started and you can telnet to the Guest OS, then you probably refer to the solution to the close caveats CSCvc53541 in the release note http://www.cisco.com/c/en/us/td/docs/routers/access/800/829/15-6-3M2-Release-Notes.pdf
If the Guest OS has not started, you may have to bundle install the image again but make sure that the Guest OS is not running before installation kicks off.
Chun
Thanks.
Checked the cave eats, but did not find anything. Double checked config according to examples.
Ended up doing a full install (bundle install with M2) and a reload. This helped.
Count of hosts registered: 1
Host registered:
    IOX Server Address: FE80::200:CFF:FEE7:7899; Port: 22222
    Link Local Address of Host: FE80::1FF:FE90:8B05
    IPV4 Address of Host:       192.168.1.6
    IPV6 Address of Host:       fe80::1ff:fe90:8b05
    Client Version:             0.4
    Session ID:                 1
    OS Nodename:                IR800-GOS-1
    Host Hardware Vendor:       Cisco Systems, Inc.
    Host Hardware Version:      1.0
    Host Card Type:             not implemented
    Host OS Version:            1.3.2.3
    OS status:                  RUNNING
    Interface Hardware Vendor:  None
    Interface Hardware Version: None
    Interface Card Type:        None
    Applications Registered:
        Count of applications registered by this host: 0
Create
Recognize Your Peers
Content for Community-Ad
