How to disable ipv6 in a container on GOS.
I am running the lxc container on IR829 GOS.
Ipv6 is automatically enabled on eth0 in the container.
I want to disable it.
Is there any way?
I did "[app -> resources -> network -> ipv6_required: false]" on this page, but it didn't work.
https://developer.cisco.com/docs/iox/#!package-descriptor/yaml-template
Alex Stevenson
I recommend to try adding the following to the Docker Compose:
sysctls:
  - net.ipv6.conf.all.disable_ipv6=1
It used to be the following , but was changed for version3 compose files:
network:
  - enable_ipv6: false
