nathan
Enthusiast
How to use the IR829/809 Mini-USB Console Cable with Linux
The blue mini-USB console cable that is included with the IR829 (and other 800 series devices) connects the mini-USB console port, under the screwed down plate, to a USB port on your Linux machine. The trick is identifying the specific device to use for the COM port. These Cisco Console instructions are very good. They worked for me with /dev/ttyUSB1. Though the instructions are from the Ubuntu site, they should work just the same with pretty much any version of Linux. I tested them with the Ubuntu Desktop 14.04 LTS version of Linux.
The Minicom application used for illustration purposes is quite basic as terminal emulators go, so you might want to look at other Linux terminal emulators. There are plenty to choose from.
Also see How to use the IR829 Mini-USB Console Cable with OSX El Capitan 10.11, How to use a Serial-USB Console Cable with the IR829 and OSX El Capitan 10.11 and How to use the IR829 Mini-USB Console Cable with Windows 10.
0 REPLIES 0
Content for Community-Ad
