Hi folks
I wonder if someone could assist me please. I am trying to get a docker based MQTT (mosquitto) server running on my IR828. This is a requirement for some IoT work we are doing.
I am using the super lightweight image from Docker Hub (https://hub.docker.com/_/eclipse-mosquitto) and I can build and run the image no issues on the dev machine. I can then package, install and activate the app on the 829. However, as soon as I start it, it stops. I am using NAT network settings, however, if I choose BRIDGE, then the container starts and continues to run (the log file does however say it is waiting for an IP address, so it can't be used). I tested the router setup with the simple nodejs web server docker example (https://developer.cisco.com/docs/iox/#!tutorial-build-sample-docker-type-nodejs-based-http-server-using-alpine-base-image/overview) and this works fine (using NAT config).
I'm not all that experienced with the creation files, so I think there may be an issue between the Dockerfile and my package.yaml file (below). The package.yaml is a modified version of the one from the nodejs webserver example.
I'm wondering if the app start process is not working, and maybe there is a clash between the Dockerfile config and the package.yaml file config.
There is also nothing specific in the either the watchdog or container log.
Any help much appreciated.
Andre
Dockerfile:
FROM alpine:3.8 LABEL maintainer="Roger Light <roger@atchoo.org>" \ description="Eclipse Mosquitto MQTT Broker" ENV VERSION=1.5.5 \ DOWNLOAD_SHA256=fcdb47e340864c545146681af7253399cc292e41775afd76400fda5b0d23d668 \ GPG_KEYS=A0D6EEA1DCAE49A635A3B2F0779B22DFB3E717B7 \ LWS_VERSION=2.4.2 RUN set -x && \ apk --no-cache add --virtual build-deps \ build-base \ cmake \ gnupg \ libressl-dev \ util-linux-dev && \ wget https://github.com/warmcat/libwebsockets/archive/v${LWS_VERSION}.tar.gz -O /tmp/lws.tar.gz && \ mkdir -p /build/lws && \ tar --strip=1 -xf /tmp/lws.tar.gz -C /build/lws && \ rm /tmp/lws.tar.gz && \ cd /build/lws && \ cmake . \ -DCMAKE_BUILD_TYPE=MinSizeRel \ -DCMAKE_INSTALL_PREFIX=/usr \ -DLWS_IPV6=ON \ -DLWS_WITHOUT_BUILTIN_GETIFADDRS=ON \ -DLWS_WITHOUT_CLIENT=ON \ -DLWS_WITHOUT_EXTENSIONS=ON \ -DLWS_WITHOUT_TESTAPPS=ON \ -DLWS_WITH_SHARED=OFF \ -DLWS_WITH_ZIP_FOPS=OFF \ -DLWS_WITH_ZLIB=OFF && \ make -j "$(nproc)" && \ rm -rf /root/.cmake && \ wget https://mosquitto.org/files/source/mosquitto-${VERSION}.tar.gz -O /tmp/mosq.tar.gz && \ echo "$DOWNLOAD_SHA256 /tmp/mosq.tar.gz" | sha256sum -c - && \ wget https://mosquitto.org/files/source/mosquitto-${VERSION}.tar.gz.asc -O /tmp/mosq.tar.gz.asc && \ export GNUPGHOME="$(mktemp -d)" && \ found=''; \ for server in \ ha.pool.sks-keyservers.net \ hkp://keyserver.ubuntu.com:80 \ hkp://p80.pool.sks-keyservers.net:80 \ pgp.mit.edu \ ; do \ echo "Fetching GPG key $GPG_KEYS from $server"; \ gpg --keyserver "$server" --keyserver-options timeout=10 --recv-keys "$GPG_KEYS" && found=yes && break; \ done; \ test -z "$found" && echo >&2 "error: failed to fetch GPG key $GPG_KEYS" && exit 1; \ -DLWS_WITH_ZLIB=OFF && \ make -j "$(nproc)" && \ rm -rf /root/.cmake && \ wget https://mosquitto.org/files/source/mosquitto-${VERSION}.tar.gz -O /tmp/mosq.tar.gz && \ echo "$DOWNLOAD_SHA256 /tmp/mosq.tar.gz" | sha256sum -c - && \ wget https://mosquitto.org/files/source/mosquitto-${VERSION}.tar.gz.asc -O /tmp/mosq.tar.gz.asc && \ export GNUPGHOME="$(mktemp -d)" && \ found=''; \ for server in \ ha.pool.sks-keyservers.net \ hkp://keyserver.ubuntu.com:80 \ hkp://p80.pool.sks-keyservers.net:80 \ pgp.mit.edu \ ; do \ echo "Fetching GPG key $GPG_KEYS from $server"; \ gpg --keyserver "$server" --keyserver-options timeout=10 --recv-keys "$GPG_KEYS" && found=yes && break; \ done; \ test -z "$found" && echo >&2 "error: failed to fetch GPG key $GPG_KEYS" && exit 1; \ gpg --batch --verify /tmp/mosq.tar.gz.asc /tmp/mosq.tar.gz && \ gpgconf --kill all && \ rm -rf "$GNUPGHOME" /tmp/mosq.tar.gz.asc && \ mkdir -p /build/mosq && \ tar --strip=1 -xf /tmp/mosq.tar.gz -C /build/mosq && \ rm /tmp/mosq.tar.gz && \ make -C /build/mosq -j "$(nproc)" \ CFLAGS="-Wall -O2 -I/build/lws/include -flto" \ LDFLAGS="-L/build/lws/lib -flto" \ WITH_ADNS=no \ WITH_DOCS=no \ WITH_MEMORY_TRACKING=no \ WITH_SHARED_LIBRARIES=no \ WITH_SRV=no \ WITH_STRIP=yes \ WITH_TLS_PSK=no \ WITH_WEBSOCKETS=yes \ prefix=/usr \ binary && \ addgroup -S -g 1883 mosquitto 2>/dev/null && \ adduser -S -u 1883 -D -H -h /var/empty -s /sbin/nologin -G mosquitto -g mosquitto mosquitto 2>/dev/null && \ mkdir -p /mosquitto/config /mosquitto/data /mosquitto/log && \ install -d /usr/sbin/ && \ install -s -m755 /build/mosq/src/mosquitto /usr/sbin/mosquitto && \ install -s -m755 /build/mosq/src/mosquitto_passwd /usr/bin/mosquitto_passwd && \ install -m644 /build/mosq/mosquitto.conf /mosquitto/config/mosquitto.conf && \ chown -R mosquitto:mosquitto /mosquitto && \ apk --no-cache add \ libuuid && \ apk del build-deps && \ rm -rf /build VOLUME ["/mosquitto/data", "/mosquitto/log"] # Set up the entry point script and default command COPY docker-entrypoint.sh / RUN chmod 777 /docker-entrypoint.sh ENTRYPOINT ["/docker-entrypoint.sh"] CMD ["/usr/sbin/mosquitto", "-c", "/mosquitto/config/mosquitto.conf"]
Package.yaml:
descriptor-schema-version: "2.2" info: name: mqtt_docker description: "Simple Docker based MQTT server" version: "1.0" author-link: "" author-name: "" app: # Indicate app type (vm, paas, lxc etc.,) cpuarch: "x86_64" type: docker resources: profile: c1.small network: - interface-name: eth0 ports: tcp: [1883] # Specify runtime and startup startup: rootfs: rootfs.tar target: ["/usr/sbin/mosquitto", "-c", "/mosquitto/config/mosquitto.conf"]
Thanks Steve, I'll give it a go when I'm back in the lab.
