04-18-2018 08:58 AM
I am working in a laboratory with IE4000 and IOx.
But I can not upload the container, I am using the example python script, but when I upload it, I return the following message:
Currently active profile: ie4000
Command Name: application-install
Error. Server returned 500
"description": "Error during app installation: [Errno 17] File exists: '/ ios / caf / work / layers / 1badee7bbaf6dec41d17fcef39daa53e91ea810b66ed204bb431cf280348d3e2'",
"errorcode": -1,
"message": "Error during app installation"
I tried to delete that directory, but the message changes to the following:
Saving current configuration
Could not complete your command: Error. Server returned 500
"description": "Error during app installation: [Errno 95] Operation not supported",
"errorcode": -1,
help
04-20-2018 01:56 AM
Guess you fixed this issue as you were asking to activate the app.
For IE4K IOx, please make sure to install and configure IOx correctly based on the guide of https://developer.cisco.com/docs/iox/#ie-4000-series/ie-4000-platforms.
And then you may use Local Manage to install/activate/start/stop apps (ioxclient is also supported).
12-21-2018 07:08 AM
The topic has started few month ago but I can add my knowledge to this issue.
Perhaps it's due to the package.yaml file that could include the cpuarch : "ppc" instead of "x86_64" and the rootfs: app.ext2 in the startup configuration (from the sample-demo files) .
Also, the GUI upload does not work correctly, try to create an ioxclient profiles and use the ioxclient application install / start / activate command for managing the application.
Julien
