dal
Participant
Participant
Running Docker apps on Catalyst 9300 - Questions and observations
Hi.
I've been playing around with Docker applications on a Catalyst 9300 lately and have some questions.
You can add applications both via the web GUI and via CLI. But the parameters, like docker run commands and ip settings does not reflect each other. Settings done in CLI does not show in web GUI and vice versa.
Why?
IOX does not seem to support IPv6 / dual stack. Can this be true?
Is it possible to use a file like docker-compose.yml to configure settings (for all applications)?
There are no automatic resource balancing. If I start up 2 applications, they take half the resources each. So when I try to start the third application, it displays an error telling me that no resources are available.
This definetly takes away the "easiness" of rolling out more applications
Not all docker applications seems to work. So how compatible is the docker service that is running in IOX?
Hope some of this issues are adressed in next version (I'm running 17.3.1)
0 REPLIES 0
Content for Community-Ad
