Cisco IOx Nodes (ISR819/CGR1120/1240/IR829/809) Hardware and Software Specification
5420
For Cisco IOx Industrial Routers, mainly there are ISR 819(C819), CGR1120/1240, IR829/809, and IR910. Here list the main OS and hardware(CPU, Memory, Flash storage) information for them. Please see the below table for details.
FOR THE LATEST INFORMATION, PLEASE REFER TO https://developer.cisco.com/docs/iox/#supported-platforms.
  ISR819(C819) CGR1120/1240 IR829/809
IP Grade IP41
CGR1120: IP20 (for indoors)
CGR1240: IP67 (for outdoors)
IR809: IP30
IR829: IP54
Ethernet ports (LAN/WAN)
4 * FE RJ45
1 * GE RJ45
CGR1120: 6 * FE RJ45; 2 * GE; RJ45/SFP
CGR1240: 4 * FE RJ45; 2 * GE; RJ45/SFP
IR809: 2 * FE RJ45
IR829: 4 * GE RJ45; 1 * GE SFP
Serial ports
(NAN)
1 * RS232
1 * RS232
1 * RS232/RS485
1 * RS232
1 * RS232/RS485
Cellular
(WAN)
GPRS, 3G, 4G
GPRS, 3G, 4G
GPRS, 3G, 4G
Wi-Fi (LAN/
WAN)
Yes (not 4G model) Yes
IR809: No
IR829: Yes
802.15.4g/e
(NAN) or LTN (NAN)
No Yes (802.15.4g/e) No
OS IOS IOS IOS
IOx Linux Linux Linux
CPU Freescale PowerPC - p102X SoC based, CPU freq ranges from 400 to 800 MHz Intel Atom Tunnel Creek CPU 1GHz, Single Core, X86 32bit Intel Atom Processor C2308 (1M Cache, 1.25 GHz), Dual Core, X86 64bit
CPU for GOS
IOS is running on the first CPU core. IOx Infrastructure and Hosted Applications are running on the 2nd CPU core.
1 x 400 MHz 32bit e500v2 (cap'd at 80%)
One thread is assigned to IOS, while part of the 2nd thread is assigned to the guest OS 1 Core for IOS, 0.5 Core for GOS, 0.5 Core for VDS
Memory 1GB 1GB 2GB DDR3
Memory for GOS 256MB for GOS 200MB for GOS 1.2GB for GOS
Storage 1 to 2 GB Flash (non-removable) 2GB 8 GB eMMC (4GB usable)
Storage for GOS 16MB for GOS Local Storage 1GB for GOS 2GB for GOS
IOx Application Development
SDK: C819 IOx SDK including PowerPC toolchains, package tool, etc.
VM applications supported.
C819 IOx SDK Cook Book: 819-IOx-SDK-Cookbook.docx
Generic 32bit X86 Linux with kernel 3.8 and standard libraries. Ubuntu 14.04.1 32bit recommended.
Generic 64bit X86 Linux with kernel 3.8 and standard libraries. Ubuntu 14.04.1 64bit recommended.
PaaS and Container Style applications supported.
Create
Recognize Your Peers
Content for Community-Ad
