Greetings, Is it at all possible to over overcome the requirement to run this lab as a non Cisco employee without actual an IR* device? __Non-Cisco employee, you will need to obtain a Kinetic account with admin privileges. The account may be pro...
view more
I installed DGLux with EFM 1.6.1 package on Centos. After login for while, I found error as attach and can't use web access anymore. Do I missed configuration something? please advice.
The Kinetic developer discussions are moving to the main Kinetic board (https://community.cisco.com/t5/cisco-kinetic/bd-p/discussions-iot-cisco-kinetic). You should get a more active community response here.
