PLEASE NOTE: The Kinetic developer discussions are moving to the main Kinetic board.
You should get a more active community response there.
Download Kinetic Manufacturing Starter Solutions-2.0
1493
Please download Kinetic Manufacturing Starter Solutions-2.0 (starter kit) from: Cisco Systems CCO
It covers the two modules below:
  • Energy Monitoring
  • Equipment Health Monitoring
You may access the below links once you installer and configured them successfully.
For the deployment guide, please refer to Cisco Kinetic Manufacturing Starter Solutions of EM and EHM 2.0 Deployment Guide.pdf.
Is there an Install Guide somewhere that covers initial installation & configuration? This appears to be an Ubuntu VM that boots to a login prompt.  Where do you go from there?
The guide is in the progress of uploading to cisco.com. Please stay tuned.
Hi Steve, Can you also please upload the Quick Starter Guides (QSG) for the Energy Monitoring and Equipment Health Monitoring modules onto this thread. That would be really helpful.
