GMM : enable features like NTP, SMTP, Syslog...
cvailler
What would be the way to configure some specific features like NTP, SMTP, Syslog
dougn@cisco.com
These are currently not currently exposed on the UI.  Will need to use custom IOS configuration feature.
Can open a support case to have it added.  Help --> Contact Us
https://developer.cisco.com/docs/kinetic/#release-notes/template-av
Provide the IOS configuration that is needed.
Just for me to understand. Who will address the development if I need SNMP for example ? Is the thru a case from Devnet or do I have to ask the BU ?
Any IOS configuration including SNMP can be pushed to the gateway using the Custom IOS Configuration template.
Right now, Custom IOS Configuration request must be sent to our support team.  From portal, Help --> Contact Us
In the future, the organization admin will be able to create these template directly.
